360 Intake Question
Old Jun 28, 2013 | 06:58 AM
rottenstock's Avatar
rottenstock
or i'll just work on building a motor from scratch...again.
Old Jun 28, 2013 | 08:41 AM
baddad457's Avatar
baddad457
Originally Posted by rottenstock
I know this will sound silly, but im just trying to get the best gas milage I can outta this old beast. I know I know. Don't need to be mockd. I do know that you can tune them enough to improve the mpg even if it's just slightly. I'll work on rebuilding the carb for now while I keep looking for the intake.
I did find one on craigslist for $200. It's a performer 390. I did shoot the guy an offer for $175 and he said he'd consider it. So maybe i'll just go pick that one up. I've got a holley 650cfm carb sitting on a shelf in my garage that needs a home and what better home to give it then under my hood.
If that Holley 650 is what I suspect it is, then it's probably a double pumper (list 4777) if so, then you'll be taking a huge step backwards if you're looking for better fuel economy , Check the list number on the choke horn and get back to us. Or just check to see if it's a mechanical secondary or vacuum secondary. Mech secondary will be a double pumper. These will not improve fuel mileage.
Old Jun 29, 2013 | 01:22 AM
rottenstock
I found a holley 4412 on craigslist for $25. Good deal?
He's also got another 2bbl but the only number on that is: c8tf-z a-788. Which is just a casting number right?
Old Jun 29, 2013 | 06:24 AM
jowilker's Avatar
jowilker
c8tf = 68 truck. I think. Where's Mr. Wilson when you need him??
John
Old Jun 29, 2013 | 12:11 PM
69cj's Avatar
69cj
Originally Posted by baddad457
I don't see how you can do that when the FE intake bolts are perpendicular to the head face. Never used a bead of sealer in place of the gaskets. End gap needs to be checked before doing that.
I've done both a number of times and it works great. If you haven't tried it don't criticise it. The all thread is not installed till the intake is almost touching the engine.
Old Jun 29, 2013 | 01:54 PM
baddad457's Avatar
baddad457
I wasn't criticizing it. So don't get your panties in a wad. I was questioning as to how it worked with the orientation of the intake bolts. I do the same thing on small block intakes (studs to drop it in place) but the bolts there are oriented differently.
Old Jun 29, 2013 | 01:58 PM
baddad457's Avatar
baddad457
The 4412 is a 500 cfm. $25 is good for a parts carb. I'd have to actually see it to determine whether or not it's worth the effort to rebuild. The C8 carb I suspect is one of those governor'd FT carbs. Very few Fords came with Holley 2 bbls aside from the FT's after the mid 60's.
Old Jun 29, 2013 | 03:52 PM
montana_highboy's Avatar
montana_highboy
You're eventually gonna want to stroke that 360 out to a 390 (everyone does in the end) so save the money on the 2bbl stuff and save it for a 390 rotating assembly.
Old Jun 30, 2013 | 12:04 AM
rottenstock
What if i didnt wanna stroke it out to the 390?
Old Jun 30, 2013 | 12:15 AM
montana_highboy
Then you're just ****ed.
Old Jun 30, 2013 | 02:58 AM
baddad457's Avatar
baddad457
You should. Thge increased stroke does wonders.
Old Jun 30, 2013 | 05:17 AM
rottenstock
I think at that point i'd rather just find a 390 to slowly work on and then drop it in when it's finished.
Maybe i'll just run it until it dies then figure it out from there.
Nick-1973-ford
Apr 10, 2019 11:51 PM
76ClydeF100
Apr 3, 2014 10:26 AM
bigreed91
Feb 1, 2010 08:19 PM
custom69
17
May 10, 2005 11:43 PM
mtcwby01
Mar 6, 2002 06:08 PM
