I've got a 76 F-250 with the 360. It's got the stock 2bbl manifold. I've got a 4bbl Holley 650 sitting on a shelf in my garage and I can get a stock 4bbl manifold for about $50. I was wondering if this would be a viable upgrade or if i should just keep my eyes peeled for a edelbrocker performer 390 or something similar.
I know those manifolds are super heavy and such, but I don't really thing weight is an issue...perhaps i'm wrong.
factory Iron intake is 70+ lbs weight makes it real hard to get manifold on with out jacking up gaskets , if you can wait for a used aluminum intake to pop up on craigslist or Ebay .
Alright, thanks for the info. I wasn't sure so i thought i'd ask..
I am running into an issue with my carb, i think. When the truck is warm, the idle is high about 2200rpms, until i pop on the throttle then it drops down to about a 1000 rpm. Any idea what is causing this or what I can do to fix it?
I thought about rebuilding the carb but I'm not sure if that's needed.
Depnding on the cost would you advise rebuilding vs replacing?
I would replace it with a newer Holley. Old carbs can be a pain in the "you know what" to rebuild. The newest Autolite 2 bbl carb is now thirty-something years old. Just me but I never had any luck rebuilding old carbs, be it a Holley or an Autolite.
That's when an engine hoist comes in handy. FE's are probably the only engine family that you need a hoist to pull and replace the intake.
True, When I install mine with a hoist I lower it to about 1 inch above the motor. I then install a 6" piece of allthread in one front and one rear opposite side bolt holes. Now when you drop the intake you'll have a perfect drop with no gasket damage. Do not use the front and rear valley gaskets. Instead lay a 3/8" bead of ultra-black RTV down, let set for app. 15 minutes and then drop the manifold in place.
I don't see how you can do that when the FE intake bolts are perpendicular to the head face. Never used a bead of sealer in place of the gaskets. End gap needs to be checked before doing that.
I know this will sound silly, but im just trying to get the best gas milage I can outta this old beast. I know I know. Don't need to be mockd. I do know that you can tune them enough to improve the mpg even if it's just slightly. I'll work on rebuilding the carb for now while I keep looking for the intake.
I did find one on craigslist for $200. It's a performer 390. I did shoot the guy an offer for $175 and he said he'd consider it. So maybe i'll just go pick that one up. I've got a holley 650cfm carb sitting on a shelf in my garage that needs a home and what better home to give it then under my hood.
Love you guys with a big erection and have to find a place to put it.
So what if you spend the money and labor and you loose a 1/2 mpg? Oh hell yes it can happen.
If you were building the engine bringing up the compression, adding a cam, it would make better sense. Some of these ol boys are going to get 7.7 mpg up hill, down hill, strong head wind or tail wind.
