FICM Removal
Old Jun 20, 2013 | 03:33 PM
waterboy_fishing's Avatar
waterboy_fishing
FICM Removal
Should one or both batteries be disconnected when removing it. If only one, which one? Thanks.
Old Jun 20, 2013 | 04:11 PM
Misky6.0's Avatar
Misky6.0
You should disconnect BOTH batteries, and leave them disconnected until AFTER you re-install the FICM.
Old Jun 20, 2013 | 05:13 PM
04badford's Avatar
04badford
Misky your probebly right, I just did the drivers side,so I wouldent weld my buckle to the wrangler snap,dont for get to use alittle dio grease back on the connections that helps slip snap those connections in, also I used 2 1x2 one for cross brace and one to press up to snap.me and Arther ritez dont get along these days
Old Jun 20, 2013 | 05:17 PM
bpounds's Avatar
bpounds
I guess safety first dictates that you disconnect the batteries. Must admit that I didn't, and I've had that thing out of there 3 or 4 times. The connectors are so well shielded that I can't imagine how you could short it out.
If you're going to disconnect them, there is no point in only doing one. You have to do both or you haven't cut the power.
Old Jun 20, 2013 | 05:32 PM
waterboy_fishing
My connectors came off fairly easy wouldn't think they would be that bad to put back in. So a little dielectric grease is a good idea. Sounds like a plan. Thanks guys.
Old Jun 20, 2013 | 05:36 PM
rattleNsmoke's Avatar
rattleNsmoke
I never disconnected mine when R&R the FICM. Thinking back I guess I should have.
Old Jun 20, 2013 | 05:39 PM
Misky6.0's Avatar
Misky6.0
That!
Plus what purpose (besides not removing one more cable) does only removing one serve?
On the flip side drop a wrench down onto the live cables and you are in need of new shorts at a minimum.
Old Jun 20, 2013 | 05:40 PM
04badford's Avatar
04badford
The only Other hard part is the Degus bracket ( I lost hide), just move the degus out of the way put some rubber close offs or caps on the hose and watch the bracket,the back bolt was apita make sure the rubber gromits are back on for shock movement(vibration).
SpringerPop
98
Nov 16, 2014 10:26 PM
da-bees
Sep 24, 2013 08:53 PM
04badford
Jan 20, 2013 11:41 AM
Bender99
27
Nov 25, 2010 09:43 AM
afinepoint
Sep 14, 2004 04:20 PM
