Installing my ficm
Old Jan 19, 2013 | 01:30 AM
04badford's Avatar
04badford
Installing my ficm
do I need to disconnect both batteries before I start,and when putting the ficm wires back on should I use dio grease,what else should I look for when ficm is out ? thanks for the Info in addvance.
Old Jan 19, 2013 | 02:40 AM
dukie1877's Avatar
dukie1877
I used dio grease on mine. I also disconnected the batteries just to be safe. It dont take long to take the batteries out. Watch out for the little round things that like to stick to holes on the FICM then fall out and get lost while your moving it from one spot to another. cant think of anything else that taking the FICM out gives you access to. Carefull the plug clips like to break if your not carefull.
Old Jan 19, 2013 | 10:11 AM
04badford's Avatar
04badford
Dude you talking about the rubber garmits right,the so called shock absorbers of the ficm world, thanks for the tips
Old Jan 19, 2013 | 10:12 AM
dukie1877's Avatar
dukie1877
Those be the ones
Old Jan 19, 2013 | 10:19 AM
04badford's Avatar
04badford
OK thanks, I was going to film the process ,But I dont think kodak makes that long of film lol, besides I dont know how to dub out all the cuzzin lol
Old Jan 19, 2013 | 07:32 PM
steelhead2's Avatar
steelhead2
I was informed by ed not to use dielectric grease on those connectors. It is an insulator, not a conductor. And the connectors already have oil tight seals on them so nothing gets in them. Just make sure theyre clean and put them back together.
Old Jan 19, 2013 | 07:38 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
I'd use a little spritz of WD 40 on the pins ( male AND female). WD40 is a water dispersant and would guarantee no moisture inside when you snap on the connectors.
Old Jan 19, 2013 | 08:28 PM
04badford's Avatar
04badford
Thanks for all the feed back guys , I didnt use the grease on the pins just the outer plastic so the connection would slip in alittle easyer and it did.alittle FYI dieletic grease,and two 1xs about 1ft long to push the connections in to snap,I found that the center connection was separated so I snap it back together FICM now reads 49 48.5,
Old Jan 19, 2013 | 08:32 PM
04badford's Avatar
04badford
something else,in the degus bottle would be our Hpop issuses a nasty white / lite brown color film , when I took the degus off and washed it out real good, did a coolent flush 1 month ago
Old Jan 19, 2013 | 09:07 PM
BLADE35's Avatar
BLADE35
That would help Save the Clips to when coming apart too
Great Idea
Old Jan 19, 2013 | 09:23 PM
04badford's Avatar
04badford
Hey Benny, happy new year. that center connector was apart,back together now ,but would or could be some issue from before what do you think.
Old Jan 19, 2013 | 09:29 PM
BLADE35's Avatar
BLADE35
Why does it drop a cylinder and misfire
Old Jan 19, 2013 | 09:37 PM
04badford's Avatar
04badford
not that I know of, but yesterday mid day stall and surge came back, today after Installing FICM and snaped plug what a diff lets keep our fingers crossed and hope its not egr cooler. havent pulled map or Icp in a while and pig tail is new.
Old Jan 19, 2013 | 09:50 PM
BLADE35's Avatar
BLADE35
I see Time will Tell
Did you inspect the Plug Terminals?? on All 3 plug
Old Jan 19, 2013 | 10:11 PM
04badford's Avatar
04badford
yes, they looked good no bends and plugs looked like new just seperated on the top side bottom side was intacked.
