I ran a 5.5k in my 98 Bounder class A. It ran the air , both of them, without a problem even in the Arizona Summer for over 5 years. The starting of the air, as stated, is the hard part. For me, I have always changed out the start capacitors in my air. I installed the SUPCO HS6 (SPP6). It is a very easy install as a basic swap out for the existing capacitor. I know on this last RV, I could not start my air on my 3k genset, now I can even at 100+ degree heat once the start capacitor was changed. Also it seems the Onan gensets are more forgiving on loads. If you have a motor starting, it seems to handle that demand much better than even the inverter type gens. I totally agree on how easy it would make it with the genset on the rig itself. It is cumbersome to hook up the portable gennys especially if you are in a Walmart parking lot just for the overnite. Middle of Kansas, Salina, in July, Walmart or Home Depot parking lot without air and the humidity is near 100 percent, not this guy.....done that and got my t-shirt!
Probably parked right beside in that same walmart..in the same dang heat. I hooked up the generators and then cable locked them and the external fuel tank so it would run all night. What a pain.
Agree. The manufacturers did away with the hard start kits about two years ago, so most ACs don't have them at all anymore. A secret within the industry was, if you complained, they would send your dealer one for free to install. They cost less than $20 bucks, so even if you just carry the factory one with you, it is worthwhile to have one on your spare parts list. I have found, although the capacitor ratings are slightly different between manufacturers, the kit from any unit will work fine in any other.
My own experience with the 5 kws is the same as yours. Never a bit of problem for three years everywhere we traveled. I also agree with your comments on the Onans and inverter versus other types.
Looks fine. Check around for prices. I can get you the dealer wholesale, if it will help, but I have to request it as it is not in my catalogs.
One final comment. If you get this darn thing, use it. There is nothing that is a greater red flag for me on a genset than seeing low hours on the hour meter. These things hate to sit, but live forever with use! When I see an ad making a big deal out how few hours there are on the generator, I cringe.
Scott I just found this thread, we have a 5K Gererac that we bought in 1998 that I have used in three trailers. When we bought it I had to make the decision between LP and Gas, we do a lot of boondocking in the CO mountains where we would have a hard time finding LP so I went with gas. I mounted a 14 gal marine tank that I bought at Cabala's with a marine fuel fill kit, the tank is mounted outside of the generator compartment in the basement area next to the compartment. We only have one A/C unit but we have run the A/C along with the electric water heater and microwave without any problems. This last winter when we where in the desert outside of Quartzsite we were with a couple that had a LP generator their biggest complaint was having to constantly run to town to fill LP tanks, they said they would never own another one.
Yeah I don't think I want to use more of my basement for that. I think the LP for me would be the way to go. Just the misses and I going cross country and staying in Wal-Mart parking lots and then dumping every third day or so. So I think I could get along just fine on the LP.
If it were to be an extended stay at a state park that would be a tredmenous amount of propane in that case.
It's all in the way you want to use it, you will really like it for overnight stops or just rest stops. Just go in the trailer and hit the button and you have instant power without dragging out potable generators and power cords.
I think that is the key. I find here in the East boondocking is relatively uncommon. Out West where there are wide open spaces, I would be looking at things entirely differently. I don't think with RVs there is ever a one-size-fits-all.
I have a separate starting battery for the generator because a lot of the time I have to use the generator to charge the batteries so I can't depend of the house batteries to start the generator.
I would be extremely surprised if you do not have to supply the cables for your genset, one to the positive lug from the battery and a ground cable or strap to the frame.
