carb question
Old Jun 19, 2013 | 04:16 PM
coryv4's Avatar
coryv4
carb question
what is that valve on the bottom of the picture? do i need it hooked up if not can i just get a regular plate without it.
Old Jun 19, 2013 | 04:37 PM
roadrash63's Avatar
roadrash63
hey
that's your EGR VALVE.
whether it needs hooked up depends on your state laws.
Old Jun 19, 2013 | 05:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If you get a 1" spacer you need to get one that covers the exhaust hole of your intake manifold.
Old Jun 19, 2013 | 07:37 PM
Salomon Trujillo's Avatar
Salomon Trujillo
I was reading through this post and I have to put a spacer in place of the EGR plate. So if I buy a 1" spacer will that cover the exhaust hole? MS has no emissions test. Just some history on what I am running- I have a 1983 Ford F150 4X4 manual transmission, a 351W from a 1985 Bronco, Edelbrock model 9906 600cfm carb. Thanks.
Old Jun 19, 2013 | 08:07 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
351's are a different style than my 460.
You may be able to find a spacer that covers.
I have yet to find one that covers the 'ear' on mine.
Old Jun 19, 2013 | 09:47 PM
Salomon Trujillo
OK, thanks. I am really new at this. I just started rebuilding my Dad's old truck and am learning as I go.
Old Jun 19, 2013 | 09:54 PM
Gary Lewis's Avatar
Gary Lewis
Salomon - I just responded in your other thread. But seeing your post here my response may be incorrect. Do you have a separate EGR valve that mounts directly to a port on the intake. Or one that mounts under the carb? The latter can't be blocked as I suggested.
Old Jun 19, 2013 | 10:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Gary,
Look at his pic in post#1.
I'm pretty sure his 351 H.O. has a gasket like this...
And that's a Holley 4180 carb, definitely not an Edelbrock.
Salomon, if you want to lose the EGR and are using an aftermarket carb, you should probably get a non EGR intake manifold like the Edelbrock Performer.
Old Jun 19, 2013 | 10:22 PM
Gary Lewis's Avatar
Gary Lewis
I'm confused. Post #1 is from Coryv4, not Salomon. But, if it is the HO then the block off is more difficult. I thought about trying it but replaced the manifold, as you suggested.
Having said that, I'm not convinced that is his problem.
Old Jun 20, 2013 | 04:03 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My gosh, I'm sorry.
Gary, you are right.
I replied to the thread and then, when my pic was quoted, scrolled up only far enough to see that EGR plate again (not the poster's userid)
I need to stay focused and observant.
Old Jun 20, 2013 | 07:33 AM
Gary Lewis's Avatar
Gary Lewis
You may still be right - it may still be the 4180 on an HO. I've lost track of what Salomon has.
Old Jun 20, 2013 | 06:12 PM
Salomon Trujillo
Well after reading all the posts and talking to friends back home I decided to buy a 1" spacer and try to replace the one already on the engine, which does have the EGR on a spacer which sits between the carb and the intake manifold. Well I started to remove everything and I found my problem...the person (i will no longer call him a mechanic) that I paid to get the truck running after the rebuild for me, didn't use the right gasket between the spacer and the manifold AND DID NOT TIGHTEN the carb down..at all!! I cleaned up the spacer with the EGR and the top of the manifold, put the right gasket on, put the spacer with the EGR on, another gasket for the carb, and then the carb and tightened it down and guess what?? It runs great now!!. Just for info, the emissions are no longer on the truck and the valve is blocked off, auto zone does have an egr blocking spacer, I just didn't need to use it. I hope this clarifies some of my issues. The gasket looks alot like the one above. Thanks for the advice all, you guys really helped out, I would have never looked at that.
Old Jun 20, 2013 | 06:43 PM
Gary Lewis's Avatar
Gary Lewis
Glad you got it fixed! But, you should still look at the gas line hoses.
Old Jun 20, 2013 | 11:41 PM
Salomon Trujillo
Glad you got it fixed! But, you should still look at s.
I did all the hoses, The rest weren't nearly as bad as the one right before the fuel pump, but replaced anyway. Good call on that, you saved me some trouble down the road somewhere!!
Old Jun 21, 2013 | 07:22 AM
Gary Lewis's Avatar
Gary Lewis
I went through them one at a time, and each time it stopped me somewhere. Glad you replaced them all.
Carmax
Dec 11, 2015 04:11 PM
Ford_Six
WTB - Parts & other
Mar 18, 2010 04:28 PM
79 bronc
May 30, 2004 08:04 AM
jdf100
Apr 20, 2004 01:50 PM
bluetop king
Aug 26, 2003 05:33 AM
