Intake question on 351w
Old Dec 11, 2015 | 01:56 PM
Carmax's Avatar
Carmax
Someone please tell what that hole is fore and what i need to plug it
Old Dec 11, 2015 | 02:08 PM
JEFFFAFA's Avatar
JEFFFAFA
It is to supply exhaust gasses to a special EGR carb spacer plate which supplied those exhaust gasses to the EGR valve that was bolted to the same special EGR carb spacer. As of now if you were to start the engine exhaust would come out of that hole. If you use that factory intake rather than an aftermarket one, you would have to fab up a plate to sandwich in between the intake and carb that would cover up that hole.
I can't help you there. I had both a fabbed plate and a used factory EGR spacer. Sent both to a fellow member here with the understanding he would send back to me which ever one he didn't use. He never sent anything back to me. I won't mention names here (351WRanger).
Old Dec 11, 2015 | 02:29 PM
Carmax's Avatar
Carmax
So could i JB weld it closed if im not running an EGR i really dont want the hassle of finding those
Old Dec 11, 2015 | 02:43 PM
351Cleveland C4's Avatar
351Cleveland C4
Wouldn't be the best way of doing it, but it would work....
Old Dec 11, 2015 | 03:23 PM
JEFFFAFA's Avatar
JEFFFAFA
Or fab a plate as I mentioned.
Old Dec 11, 2015 | 03:51 PM
crazed87bronco's Avatar
crazed87bronco
Unless you switch to a aftermarket intake manifold you wil need to rig something to block it off. Personally I would opt for a aftermarket aluminum intake and take that boat anchor stock one off. I been finding some nice aluminum ones for under $100 on different forums and Craigslist lately as I been tinkering with a 351w that's going in a 69 4x4. I would personally make a plate to cover the hole and use your spacer plate as a template. Jb weld Will do but for how long?
Old Dec 11, 2015 | 03:59 PM
JEFFFAFA's Avatar
JEFFFAFA
2X on the aluminum aftermarket intake. Only I suggest using a carb gasket listed for the vehicle that intake came out of for a template. That's what I had done years ago when I had a welder/blacksmith buddy of mine make me the block off plate I mentioned earlier. I gave him the carb gasket so he knew the outer dimensions and where the center and bolt down holes were.
Old Dec 11, 2015 | 04:00 PM
Carmax's Avatar
Carmax
Thanks for all the inputs guys i understand jb weld isnt best but it is cheapest for now will search for other options before i putty it up thanks
Old Dec 11, 2015 | 04:03 PM
JEFFFAFA's Avatar
JEFFFAFA
The walls of that hole will be lined with exhaust soot. JB Weld won't stick to that. Clean the crap out of it.
Old Dec 11, 2015 | 04:11 PM
crazed87bronco
^agreed Jeff a gasket would be a better template to go off of. And your right on the jb weld. To get that stuff to stick to anything remotely you need it spotless. Any light film of oil or soot and it won't hold on anything. Use rubbing alcohol to clean the surface before aplying the JB. Just remember you will need to remove that intake spacer one day.
Barkin 40s
Aug 9, 2010 09:38 AM
Percy
Dec 1, 2004 08:58 AM
Econo-canada
Sep 1, 2004 08:56 AM
jdf100
Apr 20, 2004 01:50 PM
bluetop king
Aug 26, 2003 05:33 AM
