Engine Teardown and Rebuild Question...
Old Jun 19, 2013 | 04:25 AM
rottenstock's Avatar
rottenstock
Im going to be pulling the motor out of my truck because it's leaking oil. I don't know how well it's been taken care of over it's life and I'm trying to make it last a long time.
I was looking over at northernautoparts and they have a master rebuild kit:
Ford 360 1968-1976 Master Kit | Northern Auto Parts
Seems like a great deal with everyhing that you get. I was going to add the Felpro KS2307 upgrade option and also a cam upgrade but i'm not sure which one to pick. I don't even know the specs on the stock cam.
*edit* I was looking at the Comp 33-230-4 280/280 adv duration .530 .530 lift. Seems to be the middle of the choices.
I don't tow a lot with my truck it's more of a daily driver.
Would that be a good kit to go with or is there an even better one? My original thought was to just get the felpro kit and regasket everything but then I started thinking about it and decided I should probably change the bearrings and such too along with the timing gear.
Should i look into upgrading the springs as well?
Old Jun 19, 2013 | 09:13 AM
RWENUTS's Avatar
RWENUTS
Have you ever rebuilt a motor?
You'll need to likely have your's hot tanked and bored if you rebuild it. You just don't buy a kit and replace parts.
So yours leaks. What condition is it in otherwise? Have you done a compression test or a leak down test?
Maybe all you need is some gaskets!
SuperDuty93
Apr 19, 2014 08:28 AM
Kylet8020
Oct 6, 2008 09:43 PM
Idiomaticman
Mar 24, 2006 07:24 PM
I6power
Sep 1, 2005 09:26 AM
hoxiii
Jan 15, 2004 03:02 PM
