2000 Expy not starting...
Old Jun 18, 2013 | 05:57 PM
timbersteel's Avatar
timbersteel
I got home this morning and went to start the wife's 2000 Expy, and I all I got was "clunk". Checked battery, was a just at 12.02, but enough to turn over. Put charger cables on my truck and her's. Got a 13.60 while charging, tried again, "clunk". Checked Fender-mounted relay, 13.50, and checked the starter-mounted solenoid contacts. All showing 13.60 or above. I can hear/feel the solenoid "clunk" when the key is turned over, but it's not engaging. I tried shorting the 2 terminals on the Fender-mounted relay, still just a "clunk".
Installed new starter and solenoid last year. Cleaned battery cables and terminals. Anybody know of any ideas on how to check the Starter-mounted solenoid without having to remove the entire starter from the vehicle? It wasn't fun removing it last year and I'm just performing normal diagnosis, until I have to yank it back off.
Can I run a jumper cable from the positive to the starter solenoid 12+ contact and see if that will do it or eliminate a possible bad wiring issue, even though I saw at least 13.50 with the battery being charged? I know that if there is corrosion, loose connection, or even a few strands of wire touching, I could still see 13.50, but not a good enough connection to deliver the amperage to the starter to engage.
Thanks again!
Old Jun 18, 2013 | 09:03 PM
projectSHO89's Avatar
projectSHO89
Go remove the serpentine belt and see if the starter can then crank the engine. Accessories can "jam" the engine.
Old Jun 18, 2013 | 10:19 PM
timbersteel
Will try in the morning. Thanks for the idea!!
Old Jun 19, 2013 | 05:04 AM
alloro's Avatar
alloro
New starters go bad too, especially if it's a rebuilt and not actually new.
Old Jun 19, 2013 | 05:16 AM
projectSHO89
Darned right! I learned many years ago that "NEW <> GOOD" the hard way, of course.
Old Jun 19, 2013 | 07:53 AM
timbersteel
Supposedly new, "Ultima" from O'Reilly. But I put a new alternator on shorterly there after and it only lasted 1 month before the bearing cup fell out and destroyed the shaft inside.
Old Jun 19, 2013 | 07:58 AM
MisterCMK's Avatar
MisterCMK
Did you try shorting the posts on the firewall mounted solenoid? If the contacts are burned up in that it could still click but not provide enough power to the starter.
Old Jun 19, 2013 | 08:40 AM
pinellas50's Avatar
pinellas50
You could try the old tap the starter motor with a hammer while trying to start the motor trick. If it cranks when being tapped it is all but certain a bad starter.
Old Jun 19, 2013 | 08:11 PM
timbersteel
UPDATE:
I got the ol' girl running again. Turns out that the copper lugs on the positive side had corrosion inside where the bolt tighten down to the post. Wired, scraped and cleaned everything, got a new battery terminal post/lug and attached it, and it fired over.
Thanks again for everyone who posted with ideas and questions. I certainly thought I was in for a cat and mouse game. Glad it was an easy fix!
Old Jun 19, 2013 | 10:16 PM
alloro's Avatar
alloro
Is this at the starter post or the post on the battery?
Old Jun 20, 2013 | 06:38 AM
timbersteel
The post on the battery.
JordanL79
Jan 17, 2017 12:44 PM
RobW248
Oct 2, 2014 06:53 AM
timbersteel
Apr 28, 2012 09:03 AM
osb
1978 - 1996 Big Bronco
Apr 11, 2011 08:15 PM
karlhr
1997 - 2003 F150
Feb 8, 2011 04:11 PM
