f150 shock tower project
Old Jun 17, 2013 | 12:23 PM
Matt 1995's Avatar
Matt 1995
Ok i drew up some planes to fab some front single single shock towers to replace my rusted out ones im a little hesitant to go ahead if any one has done this some pics would be nice or just some info seems straight forwared but insite would be helpfull ty
Old Jun 17, 2013 | 01:14 PM
warren561's Avatar
warren561
Why would you want to fabricate them? They're still available from Ford. There's also aftermarket ones available.
Prices from TASCA (about 6 months ago)
Right Spring Tower EOTZ-5A306-E $66.40
Left Spring Tower E2TZ-5A306-J $78.84
LMC has them as well as Jeff's Bronco Graveyard.
You will need to jack up the truck from the frame so that the front spring/shock can fully un-compress. You need to remove the brake line that goes through the spring tower. Then remove the spring clip and then spring. Remove the shock.
The spring towers are riveted to the frame. IIRC there's 6 rivets total. Bolt the new spring tower on with grade 8 hardware and don't forget the lock washers. IIRC the holes are either 7/16 or 1/2 depending on how you removed the rivets.
Don't forget to transfer the rubber suspension stop from the bottom of the old tower to the new tower.
Here's a couple write-ups from the other forum:
Front Spring Tower Replacement 92-96 F150 - Ford F150 Forum - Community of Ford Truck Fans
I replaced my coil spring towers today - Ford F150 Forum - Community of Ford Truck Fans
If you don't want to do it yourself, (grinding the rivets out can be a PITA), call around to find leaf spring shops (truck spring shops). That's what I did.
Old Jun 17, 2013 | 01:15 PM
JRSutton's Avatar
JRSutton
why not just buy new ones?
I'm all for saving a buck when you can, but for the amount of work it'd take to make some - I don't know, under $200 for new ones... I think I'd spend the money.
Old Jun 17, 2013 | 01:34 PM
Matt 1995's Avatar
Matt 1995
Ty for the reply but stamped steel sheets is why there being replaced for rust wanted somthing stronger like stainless steel also with cut out fender flares the would look good
Old Jun 17, 2013 | 01:52 PM
khadma's Avatar
khadma
Carpenter Local 745
These are available for sale and pretty much what you need to do.
If you have the skills and tools, by all means give fabricating your own shock towers a shot.
Universal Dual Shock Mount SAS Fullsize Classic Early Ford Bronco Ranger Explorer Solid Axle Swap
Even though these are for a double mount, the concept is there for you to use
as a starting point.
71hightoy
186
Mar 8, 2010 02:35 PM
jimandjimmer
Jan 26, 2009 05:54 AM
busted knuckle
Feb 4, 2006 08:22 PM
beat76
Dec 23, 2003 01:04 PM
pancake
May 21, 2003 08:46 PM
