Flashing OD light plus engine cuts out 94 E150
Old Jun 16, 2013 | 09:09 PM
TimLorentzen's Avatar
TimLorentzen
Hi, I have found a lot of information regarding the flashing OD light on Fords but none that are the same as what I have. One day the van was driving fine and the next as soon as it revs up, even in park, the OD light starts blinking and the engine shudders and will not rev. If you cycle the key off it will rev for a few seconds. I disconnected the battery to reset things but did it right away again. When you first start it up it idles fine, no blinking until you step on the gas. The check engine light does not come on. This thing will not even pull itself on my ramps. Help! Thanks.
Old Jun 16, 2013 | 10:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have to get the codes read to find out what's wrong. You can do it with a paper clip, no code reader required. There are instructions on the 'net. Google is your friend.
Old Jun 17, 2013 | 09:17 AM
TimLorentzen
So even if the check engine light is not on there will be codes? The OD light does not flash until you rev it up. Each time you restart it is the same, no flashing, nice idle until you rev it up.
Old Jun 17, 2013 | 09:22 AM
Mark Kovalsky
The OD light and the check engine light are separate. The check engine light tells you when there are engine codes. The OD light tells you there are transmission codes.
dyner
1997 - 2003 F150
Nov 17, 2013 08:09 AM
rustee90-150
Nov 11, 2007 05:03 PM
rachase70
1997 - 2003 F150
13
Aug 31, 2007 09:12 AM
highboy390fe
1997 - 2003 F150
Sep 1, 2006 09:43 AM
99f350sd
1997 - 2003 F150
Aug 9, 2003 06:46 PM
