Sponsored by: Auxito
Check engine and OD off light flashing.
Old Aug 30, 2007 | 08:16 AM
rachase70's Avatar
rachase70
Hi All,
This is my first post and I hope y'all can help. I have a 01 f-150 7700 with 99k on it. Last week the check engine light and OD off light was flashing. I checked the oil and it was dry. I refilled and reset the code by discon the battery. All was fine.. until this morning.. the OD off light is flashing and the check engine is back on. It shifts hard or not at all. I checked all fluids and they are fine. I need advice on this. I have no way of checking the codes unless i go to autozone. I am trying to avoid, at all cost, the stealership.. any advice would be greatly appreciated.. Thanks in advance..
Rick
Old Aug 30, 2007 | 08:40 AM
ranger88a's Avatar
ranger88a
You have a trans issue, you need to have the code pulled to see what in the trans has an issue. By the way, I work at a dealership!!
Old Aug 30, 2007 | 08:52 AM
rachase70's Avatar
rachase70
Thanks ranger.. 1st post.. first offense? lol.. I was contemplating bringing it to them anyways as the small shops dont seem to have the right equipment all the time.
Old Aug 30, 2007 | 09:21 AM
ranger88a's Avatar
ranger88a
I'ts ok, I understand. Hope this helps.
Old Aug 30, 2007 | 09:39 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
Most auto parts stores such as AutoZone will scan them for free, but you might be better off to write down the codes and post them here, most of those guys don't have a clue about the OBD-II system and will try to sell you the wrong parts.
Old Aug 30, 2007 | 09:43 AM
rachase70's Avatar
rachase70
Thanks LX. I may go to autozone first as its free.. Kinda cash limited. I will post the code this afternoon and see what hits.
Old Aug 30, 2007 | 05:51 PM
triton54's Avatar
triton54
that od light means the tranny is sending fluid through the lines at full pressure to keep it from burning up, my 97 did the same thing, i to was $$ limited at the time so i dropped the pan, changed the filter and fluid, wiped everything down real good filled it back up and about 2 days later once it all cycled through im running like a champ again. problem free for about 3 or 4 months now. O and it would slam into every gear as well once it got warm, pull over kill the engine, restart it and it would stop for a while. makes no sense to me but hey.
Old Aug 30, 2007 | 08:00 PM
rachase70's Avatar
rachase70
I had the code pulled at autozone and checked it online. P1744 Torque Converter Clutch System Stuck in Off Position. Is this correct and if so how do i fix it? Its shifting harder but isnt consistent.
Old Aug 31, 2007 | 07:26 AM
projectSHO89's Avatar
projectSHO89
p1744
Your torque converter is slipping. When the computer detects this, it maxes out EPC line pressures in an attempt to keep everything else from slipping. It's trying to keep everything else from blowing up. Works sometimes. When you turn the engine off, the computer drops out of fail-safe mode until the fault is detected again.
Since you didn't have any engine oil (which won't cause a CEL anyway), I'd suspect the tranny's maintenance has also been neglected - just a strong hunch....
You probably have a tranny rebuild in your near future. Start saving your pennies, it takes a lot of them.
You can try changing your fluid and adding some RED LubeGuard, but I wouldn't hold my breath. Once the TC slips, its internal clutches usually are permanently damaged.
TC slippage is usually caused by valve body wear or other hydraulic leak in the circuit that supplies fluid pressure to the TC clutches. Low or neglected fluid will also cause it.
Steve
Old Aug 31, 2007 | 07:45 AM
ranger88a's Avatar
ranger88a
Sorry to say, but projectSHO89 is correct. Tcc is slipping.
Old Aug 31, 2007 | 08:35 AM
triton54's Avatar
triton54
shhhhh dont speak to soon i aint ready to pay for a rebuild, maybe i got lucky on mine hope it works for you as well
Old Aug 31, 2007 | 08:38 AM
rachase70's Avatar
rachase70
I called the dealer i bought it from and they are going to flatbed it and fix it for no charge . I have only had it a mth...
Old Aug 31, 2007 | 09:00 AM
Canadian98f1504x4's Avatar
Canadian98f1504x4
wow good dealer and u r lucky
Old Aug 31, 2007 | 09:12 AM
rachase70's Avatar
rachase70
Thanks for all the input. I wouldnt have called them if it was something easy i could take care of but all of the input pointed to something i wasnt mechanically inclind to handle. I may be vehicleless for a cpl days but it will be worth it. And considering my warranty ran out I guess i am lucky.
texbigred1
Oct 23, 2016 09:52 PM
Gwilkrrs
Apr 20, 2016 06:51 AM
ImAGirl
Aug 3, 2015 03:13 AM
ST58
Feb 16, 2015 08:37 AM
lamarafronhe
Jul 7, 2004 09:10 PM
