Trouble Code Crazy
Old Jun 16, 2013 | 12:10 PM
Tractorman1215's Avatar
Tractorman1215
Trouble Code Crazy
Okay so fixed the throttle body bolt problem and trans problem drives great no problems. But im getting like 6 DTC codes on my scan tool which are
DTC 121 TPS Fault (Which i replaced not even a week ago) During KOEO/KOER
DTC 172 02 Not heated enough bank 1 too lean During KOEO and KOER
DTC 53? Sorry forgot the code but it was Insufficent RPM change during KOER
Sometimes Id also get Not enough Exhuast Recirculation Code (im thinking because its reading too lean) During KOEO
Now the truck runs and drives fine its rough on idle when its cold sometime, but usually no problems. Any Ideas?
Also the truck is a MAP truck if it helps.
As well the previous owner changed the Distrubtor Cap, Spark Plugs and wires. Checked the gaps on plugs all good. I asked him if he made sure the timing was good on the cap he didnt. Hope this helps.
BigDa
1997 - 2003 F150
Jan 18, 2010 08:44 PM
bones281
1997 - 2003 F150
Jan 16, 2010 06:14 PM
RAPTOI21
1997 - 2003 F150
Feb 25, 2008 07:58 PM
ameritaz3038
Aug 26, 2007 10:52 PM
nobodyspecial
18
Feb 3, 2007 10:05 AM
