Sponsored by: Real Truck
Reverse Gear Signal Wire
Old Jun 15, 2013 | 09:43 AM
Scottay's Avatar
Scottay
I installed a reverse camera to my new Pioneer in-dash nav head unit this morning. I wired (at the rear of the truck) the power signal lead to the reverse wire at the trailer connector. I also need to wire a reverse signal input into the back of the head unit. I really do not want to run a power lead from the rear of the truck to the cab. Is there a wire under the dash I can tap into, or could I use the wire going to the backup alarm that’s somewhere under the dash (if I can find it). 2010 F350 deisel, crew cab, 4WD, long bed.<O</O
Old Jun 15, 2013 | 04:06 PM
Yahiko's Avatar
Yahiko
One place I found that wire on my 06 was in the passenger side
kick plannel where the plug for the parking assist is located. If
you don't have a wiring diagram you can goto ALLDATA
and get a short term access and download what you need. Also you
can download everything for you year truck and save it for later uses.
Sean
Old Jun 15, 2013 | 04:17 PM
tim.moman's Avatar
tim.moman
on my 04 I had to pick up reverse from the kick panel as well. for 2010 I thought ford had a reverse wire already up in the radio harness. You should check before you dig to far elsewhere.
Old Jun 15, 2013 | 04:48 PM
Yahiko's Avatar
Yahiko
"Dooooh!" : Click for sound
The 2006 has VSS but no reverse. So if the OP is working on a 2010 a copy of the
stereo wiring diagran should do the trick.
Sean
Old Jun 17, 2013 | 10:27 AM
Scottay's Avatar
Scottay
Ended up running a lead to the rear of the truck. Didn't think of the factory radio harness, although the factory system was a basic CD/AM/FM (nothing fancy). Not sure if the harness was/is wired for all system though. I will take a look at the wiring diagram. I would prefer the connection to be behind the dash instead of under the truck (one less wire to have snow and ice hang on. Thanks all.
Old Jun 17, 2013 | 03:54 PM
Yahiko's Avatar
Yahiko
One way to keep water out is heat-shrink tube with mastic in it.
The stuff melts and seals the ends to keep water out.
You can pick up this kit and use the tube for the project
Flotec Submersible Wire Splice Kit-TC2172 at The Home Depot
Sean
Old Jun 18, 2013 | 11:07 AM
bbender85's Avatar
bbender85
there is a black and pink wire that runs into the fuse block you can tap into. just finally installed my camera a couple weekends ago and googled wiring it, got the info on the black/pink wire on another truck forum and it worked like a charm.. i'll see if i can find it.
EDIT: found it. hope i don't offend the powers that be by posting this, but this is the best info i found on the net (and why not have it on the best ford site on the net too, no? )
http://www.thedieselstop.com/forums/...8/#post2032452
Old Jun 18, 2013 | 12:44 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I know it's a little late, but most trucks have a reverse power lead in the overhead that goes to the rearview mirror. the reverse lead is used to turn off the dimming mirror at night. On my old truck I had retrofitted a 2010 F-150 mirror and camera and fought this wiring fun for several days.
2008 truck
2009 truck
2011 f-150
Old Oct 20, 2013 | 02:48 PM
Mickey.chatman's Avatar
Mickey.chatman
Do you have a picture of this wire and location. I also have an 04 and I need assistance
Old Oct 20, 2013 | 04:38 PM
Misky6.0's Avatar
Misky6.0
Auto dim rear view mirrors have a reverse wire so they undim at night in reverse.
The wire is likely in one of the pillars.
Sent from my Sprint PC36100 using IB AutoGroup
kevgrn114
Jul 31, 2014 07:47 PM
mr. grieves
Feb 24, 2014 01:10 PM
grec-o-face
Dec 28, 2013 09:49 AM
pminne
Feb 25, 2010 07:53 AM
pep100
2004 - 2008 F150
May 11, 2008 02:42 PM
