troubleshoot 2005 6.0 using AE scanner
Old Jun 15, 2013 | 09:01 AM
metro employee's Avatar
metro employee
hi ,
i am having trouble with my 6.0.
210 k miles, egr delete
doesnt get boost until 2500 rpm
i am hoping someone can guide me tru what to look for when using ae to diagnose source of problem.
at one time the no boost issue would not surface until i drove it a ways, like 60 miles then shut it off and restarted it.
Thanks
Old Jun 15, 2013 | 06:32 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Jun 15, 2013 | 08:53 PM
Edogsf350's Avatar
Edogsf350
Are you getting any DTC ? you can Use AE to actuate Vgt make to make sure it's moving. Then the egr you can see actual and commanded. If you don't see anything obvious I'm sure some one will be along and they will ask you to post some other values
Old Jun 16, 2013 | 07:42 AM
tex25025's Avatar
tex25025
With regard to how the delete was done, may or may not have an EGR valve to actuate. Even if he does with the delete that he has, it should be welded off to where it's functioning, but not really doing anything, it's out of the loop.
In that case, I would be looking to see what EGT values he is getting. If they skyrocket while he is trying to build boost. Lack of power, EGR being messed with, always has me thinking up pipes first.
<object style="position:absolute;z-index:1000" type="application/x-dgnria" id="plugin0" height="0" width="0">
</object>
Old Jun 16, 2013 | 01:01 PM
metro employee
no egr to activate
i will check for dtc
Old Jun 16, 2013 | 02:14 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I don't have AE but I think you can command VGT (turbo) to boost while monitoring Map (intake manifold pressure) and EBP (exhaust pressure). If one increases and the other doesn't, suspect the non working one. If neither changes much suspect turbo issues.
MAP, EBP, should be close (+or- .5) of Baro with the key on engine off to verify sensors are ok to start with. Numbers may seem way off as displayed but be sure of the scale psi vs kpa for example.
You may want to check/clean MAP hose and fitting on passenger side intake manifold runner. Also check/clean EBP sensor and hard line coming from driver side exhaust manifold.
Old Jun 16, 2013 | 05:03 PM
metro employee
does anyone know where to command vgt using AE
i see where i can "open" or "close" it, but no control in %
Old Jun 16, 2013 | 05:08 PM
tex25025's Avatar
tex25025
Testing the duty cycle and/or for turbo fault, you are going to need to access the enhanced powertrain module and go into the testing tab and find the corresponding test that you want to perform.
</object>
Old Jun 16, 2013 | 05:50 PM
metro employee
ok i ran the truck,
dtc = exaust back pressure sensor
when i logged the ebp and map
map was usually 8 to 10 psi lower then ebp
i still dont see where to command the % for vgt i have enhanced ford activation
Old Jun 16, 2013 | 06:05 PM
metro employee
i did more reading going to clean ebp tube
Old Jun 16, 2013 | 06:43 PM
tex25025's Avatar
tex25025
Are you looking at the drop down menu for the tests or are you just looking at the sensor readings tabs?
Friend of mine has my netbook with the program on it, so I am not able to look at it right now.
</object>
amdriven2liv
Jun 6, 2016 09:58 PM
ultrasks700
Apr 23, 2014 06:50 AM
05F350AB
Feb 16, 2013 05:57 PM
Blacksmith101
Aug 20, 2011 05:35 AM
Duksrule
Sep 21, 2010 04:40 PM
