Surging Black Smoke now dead
Old Jun 16, 2013 | 01:40 PM
Rock Your House's Avatar
Rock Your House
Looking for advice on possible issues. 03 model 6.0
Started running rough, higher idle, surging, would go away after running. Intermitant, engine light.
Codes
P132B Turbo boost gate performance
P2285 ICP sensor low
P0404
P1408
Now dead on driveway. Considering replacing ICP Sensor
Recently (5K) removed EGR, added up pipe & oil cooler
Old Jun 16, 2013 | 04:50 PM
senix's Avatar
senix
Moved to the 6.0 forum for better assistance
Old Jun 16, 2013 | 11:20 PM
04badford's Avatar
04badford
Codes
P0404
P1408
The p0404=EGR A control circut Range and Performance
p1408=EGR flow out of self test range
one or the other could be from unhooking EGR valve did they clear the codes after Installation,may need to pull and clean the soot off and make sure the connection is firmly plugged back in.
the p-2285=ICP circut low would be ICP /Pigtail as you well know ICP is behind Turbo.
p132b turbo gate ? havent read up on that one yet but Boost would be from Map EBP, VGT sensers, you could try cleaning
MAP connection to Intake
EBP and tube to manifold ( just make sure the hole in the senser is clear and run or take tube off or run weed eater line thru past the manifold no blockage.
need to post some values for the guys to follow
MAP ,baro,EBP,ICP, ICPV,FICM,boost,Whats the batterie test separete may need to put them on a charger
Old Jun 16, 2013 | 11:48 PM
BLADE35's Avatar
BLADE35
Unplug the ICP Sensor And STart It UP!!
Nick Fogarty
May 22, 2019 03:18 PM
phatboy7
Jan 28, 2014 10:33 PM
dmonell
Oct 11, 2013 06:04 PM
dmonell
Oct 10, 2013 11:42 AM
embry1123
Mar 18, 2011 06:40 AM
