Voltage question
Old Jun 11, 2013 | 10:07 PM
cutlass's Avatar
cutlass
Voltage question
I've been watching my Prodigy P3 brake controller lately since it has the ability to display voltage while I'm driving.
Wat I'm seeing is a voltage of no higher than 13.7 and each time I have my foot in the pedal even just a little bit and the injectors are doing their work, I see voltage usually between 12.2 and 12.8. When the AC is running is when I see the lower 12's. As soon as I let my foot off of the pedal, it pops up to lower to mid 13's in voltage.
The other thing that I am noticing is that the longer the trip is, towards the end of the trip has the lowest voltage reading average. It's like a downward trend in voltage the longer I am driving and it's harder for the voltage to recover after throttle.
Anyone have any ideas if this is remotely normal or an indication of either weak batteries or weak alternator or both?
Thanks,
Drake
Old Jun 11, 2013 | 10:10 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Have you cleaned your battery cables lately? I don't think your symptoms are normal.
Old Jun 12, 2013 | 12:17 AM
cutlass's Avatar
cutlass
I think the cables are good. One thing I noticed tonight after looking under the hood is that 4 hours after last using the truck, the alternator is still quite warm to the touch. Would this be evidence of simply it working over-time to make up for bad batteries or is my alternator on it's way out?
Thanks,
Drake
Old Jun 12, 2013 | 06:13 AM
Tugly's Avatar
Tugly
There has been a surge of alternators failures (pardon the pun)... including mine. Stepping on the accelerator should not drop voltage in any way. Way to be on top of it.
Old Jun 12, 2013 | 06:22 AM
Pitcrw6's Avatar
Pitcrw6
Ck ur alternater in the morning after its been sitting all night and see if its still warm, if so then I would say the diode in the alternater is bad. Take it in and get it bench checked. If it cks good then u have a drain somewhere else.
Old Jun 12, 2013 | 10:47 PM
cutlass's Avatar
cutlass
It was a bad alternator. Had an extra Ford alternator laying around that I picked up from a salvage yard, dropped it in and viola! No more excessive engine noise, no more engine stutter, better throttle response right off of idle, headlights and turn signals brighter, less engine noise, engine runs smooooooth!
Voltage is behaving as expected now on my brake controller voltage read-out.
I had no idea a bad alternator can wreak so much havok on these trucks.
I also was having issues with the truck running crappy just before it rained or stormed out. I will have to see if that still continues, but I doubt it seeing how much improvement this has already made to my trucks problems.
I'm truly amazed!
Drake
Old Jun 12, 2013 | 10:50 PM
Shake-N-Bake
I'm truly amazed!
Drake
Nice!
Old Jun 13, 2013 | 07:11 AM
Tugly's Avatar
Tugly
Think of it this way: The truck is a computer-controlled electro-mechanical device... that relies on sensor voltage to adjust the programming. Wonky voltage to sensors = wonky sensor readings = wonky instructions to engine. Garbage in - garbage out.
Old Jun 13, 2013 | 10:19 PM
carltonwebb's Avatar
carltonwebb
I am fairly certain that the voltage regulator on these have a two speed circuit to them. One charging circuit for lower rpm and one for higher rpm. I have never studied it really hard but that was how it was explained to me quickly one time when i had one that would charge at idle but throw a light and quit charging at highway speed.
Old Jun 14, 2013 | 01:15 PM
roostercrows's Avatar
roostercrows
Glad you got it figured out with such great results!
Krueger1
Apr 4, 2019 10:16 PM
xaviar
May 8, 2015 07:01 PM
Whisker
Nov 14, 2014 05:21 PM
bigred66
Jan 21, 2013 09:51 PM
Polkster
18
Oct 14, 2009 03:43 AM
