Top End Cleaning
Old Jun 9, 2003 | 07:02 PM
Rtpjunior's Avatar
Rtpjunior
Top End Cleaning
I have heard on other forums about a "Top End" carbon cleaning that can be done by the dealer. It involves solvent being introduced into the intake manifold, allowing it to soak, then running the motor to clean out carbon deposits. Does anyone have any info on this ? Good/bad results ? Cost ?
Old Jun 10, 2003 | 08:32 PM
madman666's Avatar
madman666
Top End Cleaning
I’m very fuzzy on how to use this stuff.
The cleaner your talking about is a GM product.
But that doesn’t mean anything; it’s a very good product.
This was used more or less on carbureted engines, but can be done on EFI.
It says how to do it on the bottle, but here’s what I remember.
With the engine running pour the top end cleaner in the intake, just about till it stalls keep pouring it so the engine keeps wanting the stall, but don’t let it. The amount you pour in is fuzzy but I think 1/2 to 3/4 of the bottle.
after this you shut the engine off, and pour the rest of the cleaner down the intake, leave it sit, the start the engine and hold it at wide open throttle, black soot pours out the exhaust usually, its all the carbon from the engine.
Just hold it at redline till it’s clean, some mechanics even take it out on the road, and just stick the accelerator to the floor (severe beating).
Its fun.
If you've had this done to your car that’s probably what the mechanic did.
Oh and by the way this was done on a lot of cars that grannies and old people owned, the cars usually came in with a slight drivability problem, just needed the carbon cleaned out!!!! Hehehehe…..
Old Jun 13, 2003 | 11:08 PM
99f350sd's Avatar
99f350sd
Top End Cleaning
I used to work at a GM dealership we did this alot to caddy's...
I would not recomend this on a normal running engine. Most cases it does nothing because there's nothing to clean. Plus you are supposed to take off your cat converter. Use a good fuel inj cleaner every 6 months or so... and you'll be fine.
Boats12
Nov 17, 2019 04:49 PM
jor
Jul 4, 2016 08:38 PM
madscientist
2015 - 2020 F150
18
Apr 29, 2016 11:33 AM
latechbanjo
Aug 17, 2015 12:11 PM
Cruiseomatic
Jun 29, 2006 09:10 AM
