Will internal engine parts (ie cams, pistons, etc) made for a 4.6L SOHC Mustang engine work in a 4.6L SOHC F150 engine? I might be wrong, but shouldn't both engines be the same?
My understanding is that you can swap parts if you match the right years and plants etc. But the cams,for example, will not improve performance (in fact your engine won't run right) unless you also change the intake and ECU.
