Replacement fuel tank sender float assembly
Old Jun 11, 2013 | 12:26 PM
mhwessel's Avatar
mhwessel
I am looking for a replacement fuel tank unit, tank sending unit assembly for in cab fuel tank 1971 F100 2WD. I think the part number may be D7TZ-9275-G. I am also looking for a fuel tank selector valve assembly and I think the part number may be D2T2-9189. The selector is on the floor of the cab along side the driver seat. The fuel selector appears to be jammed as it cannot be moved from the main tank position.
Any ideas where I can obtain these parts?
thanks
Old Jun 11, 2013 | 04:55 PM
flyboy2610's Avatar
flyboy2610
For the sending unit:
New Gas Tank Sending Unit 1968 1969 1970 1971 1972 1973 1974 Ford Pickup Truck | eBay
Truck Parts and Truck Accessories (item #5)
I can't help you with the selector switch, though.
Old Jun 11, 2013 | 10:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mhwessel
I am looking for a replacement fuel tank sending unit assembly for in-cab fuel tank, 1971 F100 2WD.
The part number is: D7TZ-9275-G (replaced C1TZ-9275-K) = 1961/77 F100/750.
I am also looking for a fuel tank selector valve assembly, the part number is: D2TZ-9189-A (replaced D0TZ-9189-B).
Remove the float from the sender, shake it to hear if gas is sloshing around inside.
The float is available by itself, the original is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
COAZ-9202-B .. Fuel Tank Sending Unit Float / Available from Ford
Applications: ALL 1957/79 Passenger Cars/Trucks, 1961/79 Econolines and 1966/79 Bronco's.
Carpenter sells a one piece brass float for around 5 bucks that will never leak.
D7TZ-9275-G =
DAVE MOORE FORD in Beeville TX has ONE = 361-358-8877.
NOS PARTS LTD in Waxahachie TX has TWO = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has FIVE = 800-543-4959.
D2TZ-9189-A =
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
thatsrealnice
13
Jun 15, 2018 03:57 PM
GoatMoto
Mar 10, 2017 11:29 AM
autofive
Aug 15, 2013 03:21 PM
Tees77f150
15
Mar 7, 2009 11:08 PM
AlexKonya
Jun 15, 2008 07:00 PM
