Fuel sending unit
Old Mar 9, 2017 | 06:49 PM
GoatMoto's Avatar
GoatMoto
Fuel sending unit
Need a bit of help. have a 78' F250. Rear tank, this weekend put just over 10 gallons of gas in the tank. Fuel gauge showed darn near empty. (Just bought this thing, so not sure how accurate fuel gauge is). 19 gallon tank, should be at least 1/2 full. Anyhow, needle only comes up just past empty. So I'm thinking likely a bad ground because when a switch to the aux. tank, the fuel gauge works.
So I pull the ground wire on the rear sending unit and touch to a good ground. Dial doesn't move except just above E. Hook this back up, and pull the other wire and ground that. Same thing. I don't ground the wire, turn the key, same thing. Needle comes up just a hair above E.
So, have I gone about this all right? What does all of this point towards? Bad wiring? Bad sending unit? Where should I go from here?
This is probably a really newbie/dumb question, but this is my first resto.
Old Mar 9, 2017 | 07:03 PM
redcreekauto's Avatar
redcreekauto
Float could be out of adjustment or has soaked up fuel over time. If its brass it may have filled partially with fuel. Or could just be a bad sending unit.
Old Mar 9, 2017 | 10:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
MY $.02 to test it and to remove tank. https://www.ford-trucks.com/forums/1...l#post14696841
Fuel sender
76-up F100-350 >s/n C00,000
Use with aft axle steel tank, includes gasket
D7TZ-9275-D
Bob Hoover Ford-Mercury, Vienna, IL (618) 658-9218
Brighton Ford, Brighton, MI (800) 336-3305
Beau Townsend Ford, Vandalia, OH (937) 898-5841
Own Ford, Jarratt, VA (434) 535-8515
Vintage Fords, Beaver Dam, WI (877) 846-8243
Old Mar 10, 2017 | 10:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TZ-9275-D (replaced D3TZ-9275-A) .. Fuel Sending Unit-Use with Aft Axle Steel Fuel Tank / Marked: D3TF-9275-AA or D7TF-9275-DA / Obsolete
1973/79 F100/350 (1973 F100 302 from serial number R20,001).
OWEN FORD in Jarratt VA has 1 = 434-535-8515.
BOB HARPER FORD in Vienna IL has 1 = 618-658-9218.
KLIMESH MOTOR SALES in Calmar IA has 3 = 563-562-3241.
NOS PARTS LTD in Waxahachie TX has 5 = 972-937-2201.
VINTAGE PARTS INC. in Beaver Dam, WI has 89 = 877-846-8243.
Updated information.
Old Mar 10, 2017 | 11:07 AM
77&79F250's Avatar
77&79F250
Thank you for the updates.
Old Mar 10, 2017 | 11:29 AM
78 PEB's Avatar
78 PEB
If you directly ground the wire that attaches to the sending unit that goes to the gauge, does the gauge go to full? If it does, its not the gauge or wiring......its the sending unit.
Pitcrw6
Apr 2, 2014 04:36 PM
Phlanx
Aug 8, 2013 02:04 PM
mhwessel
Jun 11, 2013 10:13 PM
Redmanbob
Feb 14, 2013 12:11 AM
daddy hadday
Aug 12, 2011 12:32 PM
