1977 351M Temperature Issues
Old Jun 11, 2013 | 10:48 AM
rbell14's Avatar
rbell14
Recently purchased a '77 f150 with a 351M. Noticed that on the freeway it was running hot, pushing 220+ at about 68MPH. City driving it runs about 195-205ish.
Truck has 35" tires and has a manual granny tranny. I'm concerned with temperature changes and would like more consistency.
Planning to flush the system and install new thermostat (M.Craft RT-139)
Anyone have suggestions? Stock radiator, stock fan with shroud.
Old Jun 11, 2013 | 12:08 PM
Filthy Beast's Avatar
Filthy Beast
That's a bit hot. You should be around 200 (give or take) city/freeway....about normal for M blocks.
If your water pump isn't leaking, hoses aren't bad/squishy and the heater core is good, a good flush would definitely be next in line.
No coolant leaks or needing to add any? I'm presupposing the T-stat number you posted is for the M blocks, yes?
Old Jun 11, 2013 | 12:15 PM
rbell14's Avatar
rbell14
Heat Issue
Just noticed that I have some leaking from the heater core onto the interior of the passenger floor. Small amount but I think I neeed to replace that and then flush the system to see where I'm at.
I also assume the gauge is accurate (it's after market with numbers)
Old Jun 11, 2013 | 04:21 PM
montana_highboy's Avatar
montana_highboy
Give your lower rad hose a squeeze to be sure there's a spring inside.
Old Jun 11, 2013 | 07:33 PM
rbell14's Avatar
rbell14
temps
Confirmed lower radiator is squezable and appears to have no spring inside. I assume i should replace that then heater core then flush and see where im at?????
Other thoughts?
Old Jun 11, 2013 | 07:48 PM
Cory281's Avatar
Cory281
Make sure the truck has the right thermostat for a 351m/400. Sometimes a thermostat from a 351 windsor gets put in. They are different thermostats. The thermostat for a 351m/400 has a bypass in the block that needs to be covered up whenever the thermostat opens, if it has a windsor thermostat then it doesn't get covered up and the coolant does not cycle through the block like it should.
Old Jun 12, 2013 | 07:17 AM
rbell14's Avatar
rbell14
Rad Hose
Since I have a 3 inch body lift how do I ensure I get the right length radiator hoses. Do I just have to take the old one and match up with another hose?
Old Jun 12, 2013 | 07:24 AM
xkpsanit's Avatar
xkpsanit
If you have a stock fan shroud, the radiator had to have been lowered. The stock hoses should fit fine.
Old Jun 12, 2013 | 08:11 AM
buttwheat's Avatar
buttwheat
This^^^^^^^ I put the wrong t'stat in my truck thanks to the jerks at autozone.
Last edited by buttwheat; Jun 12, 2013 at 09:29 AM. Reason: didn't know A55hats was an unexecptable word sorry
Old Jun 12, 2013 | 09:18 AM
rbell14's Avatar
rbell14
Lower Hose
No spring inside the lower radiator hose. NAPA parts do not have a spring in the facotry hose. Does everyone just add a spring or is there a unique part # I should consider to ge a hose with a spring.
NAPA said design has changed and no spring is needed now-a-days?
Old Jun 12, 2013 | 09:27 AM
buttwheat's Avatar
buttwheat
A spring is not necessary due to the stiffness of the modern hoses with the exception of running a high volume pump. If your lower hose is old and weak then yes it could collapse under the suction pressure.
Old Jun 12, 2013 | 09:40 AM
Filthy Beast
Agreed.
I run a Gates hose, #21053, has an internal spring. Their website says what buttwheat indicated about the newer hose materials.
I guess it's an old hose...had it in there for a few years now.
Old Jun 15, 2013 | 09:08 PM
rbell14's Avatar
rbell14
update
Replaced t-stat and of course it had the incorrect one it so that was good to get corrected. Also replaced leaking heater core. Flushed system and two new hoses and its been running cooler. Ranges from 195 to 205 now which is much better depending on my speeds.
Old Jun 16, 2013 | 12:05 AM
buttwheat's Avatar
buttwheat
Good to hear
bull jr
26
May 2, 2018 10:11 AM
Jmc33
Mar 20, 2017 10:47 PM
burntice55
1978 - 1996 Big Bronco
Oct 30, 2014 06:56 PM
jm5770
Apr 8, 2010 12:58 AM
Ferrite
Jan 18, 2002 04:21 PM
