robert shaw thermostat or ford
I got my first one with a FlowKooler kit. Seems they are connected? The 333-180 is hard to find now, as is 333-160 ..... but as far as I know the 333-192 is still made, though marketing has changed maybe?
If they get too hard to find, I'll have to use my spare some day ....
.... or remove the "hat" from a dead 333-series and install it on a 330-series .... that too would work. Just a press fit I bet.
Crap when I put the motor in my truck I had to go 4 different part stores before I found one that said they had a thermostat for my truck. It was an Auto Zone where I bought it I didn't notice if it had a hat on it or not but it has run hot (hot not over heating)from day one. I guess to be on the safe side I should just order a new one from Napa and put it in.
I'ld make sure.
The hat missing will certainly result in hotter temps as the bypass is not restricted so even as the T-stat opens .... much coolant just recirculates through the wide open bypass channel to be pulled through the W-P and shoved back through the engine .... instead of radiator coolant.
On a hotter day at highway speeds, I saw mine steadily rise when I first swapped a new T-stat when I first installed AC and started working on getting the motor to stay cool, I had to pull over and let her cool a bit. That's when I learned .... and lead to me finding out about "the hat" (and FlowKooler stuff and started using RS 333-192 T-stats and modded my WP with a disc).
In the 351W/289/302s, the restriction is the kink in the bypass hose with the flattened insert, that's not there with 351C/351M/400s (that have a wide open bypass when cool to speed heating up and eliminate cavitation, yet which restricts when hot so coolant is redirected through radiator).
nebechanezer
11-13-2006 09:04 PM
timothy47129
10-14-2006 03:13 PM
