emergency brakes
Old Jun 11, 2013 | 06:54 AM
cappo's Avatar
cappo
emergency brakes
So I finally got around to installing new emergency brake system on my '99 E150. all new cables. Does anyone know the proper way to adjust them. I tightened them up until I felt a slight drag on the drums (without the brakes activated). but when I try them out they are not stopping the vehicle very fast. I'm sure they need more adjustment but don't know how far to take them. Thanks
Old Jun 11, 2013 | 04:41 PM
joshofalltrades's Avatar
joshofalltrades
first of all, the rear drum brakes should be properly adjusted, then the parking brake cables should be adjusted so that the shoes start to move toward the drums as soon as you start moving the pedal down. in many cases, our parking brakes don't work too well, no matter what we do to them.
awhile back i read a thread on here about someone having a bent arm inside the drum, i think its the one that the cable connects to, and pushes the shoes out, i think his was bent in a way that made it much less effective than normal. maybe try a search along those lines - i don't remember the details
Old Jun 11, 2013 | 04:45 PM
cappo's Avatar
cappo
thanks for the info. yes I can pretty much stand on them now and it doesn't stop too well
Old Jun 11, 2013 | 08:35 PM
Club Wagon's Avatar
Club Wagon
FYI, the FORD Econoline cable operated rear braking system was designed as parking brakes. It was not intended to "stop" a moving van.
Originally Posted by cappo
emergency brakes...... I can pretty much stand on them now and it doesn't stop too well
During normal braking the vast & overwhelming majority of stopping power is delivered by the front brakes.
Even under ideal circumstances rear brakes alone might only provide 20-30% of total braking effect. By themselves rear brakes could never "stop too well".
Old Jun 12, 2013 | 06:00 AM
cappo's Avatar
cappo
my thinking was they are also a backup should the main brakes fail. on a smaller vehicle like our Dodge Caravan the emergency brake will stop the car.
Old Jun 12, 2013 | 08:59 PM
Club Wagon's Avatar
Club Wagon
Of course the rear brakes alone "will stop the car" eventually, IF they're functioning properly. It's just on these antiquated 5000lb light duty trucks FORD engineer's "thinking" produced a system that does not "stop too well".
BigBlockF350
56
Apr 2, 2013 05:55 PM
BIG ATS
Mar 15, 2012 10:57 AM
Daytona F1
May 10, 2010 08:55 PM
61 uni
16
Sep 17, 2007 12:15 PM
Blastomy
Jan 11, 2006 06:59 PM
