Self Adjusting Brakes?
Old May 10, 2010 | 04:40 AM
Daytona F1's Avatar
Daytona F1
When were self adjusting brakes first introduced?
To be more specific, do 51 F1's have self adjusting brakes and if not how are the rear brakes adjusted?
Thanks
Old May 10, 2010 | 06:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961 on passenger cars, 1964 on F100/250's & Econolines, 1966 on Bronco's.
The self adjusters only work (if they work at all!) when you back up and step on the brake.
The system was a troublesome turd from day one. The self adjuster cable has a nasty habit of snapping, allowing its cable guide to float around inside the drum.
If that guide gets hung up between the shoe and brake drum, when you step on the brake, it chews the hell oughtta both parts. Not pleasant!
The other problem with the self adjusters is that they will not function when rust and road grime are present.
Thankfully, NAPA has offered a kit...for years...that takes the place of the PITA self adjusters.
Old May 10, 2010 | 08:55 PM
Julies Cool F1's Avatar
Julies Cool F1
So, no, unless you have changed out your rear end to something after 61 car or after 64 truck, you don't have self adjusting brakes. There is a procedure for adjusting the brakes in the shop manual - don't have one - time to get one.
It simply involves tightening up the shoes using the slot in the backing plate and turning the adjuster until the shoes just start to drag then backing off until they don't drag any more - about 1/4 turn. Adjusting the hand brake cables is a little more involved. I quote that procedure in this thread:
https://www.ford-trucks.com/forums/7...o-bracket.html
Post #6.
MainetoDC
Jun 30, 2017 04:14 PM
hooler1
Mar 14, 2016 02:32 PM
Jim and Austin
Jan 10, 2016 01:08 PM
cappo
Jan 29, 2015 09:55 PM
johnson2007
26
Sep 24, 2011 01:25 AM
