bertha vib
But here it is not icp not harness both new
new ebp sensor and cleaned tube
new upper boots and plenium boots
new uvch and glow plugs
new 175/145
New frx and hpx
new w wheel and 6637 with foil delete
After running the truck on the solace pro thesis is what came up
p0278 cylinder 6 contribution/balance fault
P0238 turbo boost sensor A circuit high
P1249 wastegate control valve perform
p0603 internal control module KAM error
P0344 cam position sensor circuit intemittent
And the vib that I'm getting is coming from Eng front hubs and axle spin free
vib coming from Eng at all speeds around 1200 rpms worst under load at final drive
ive got a diablo sport tuner that I can read live numbers if needed
was told to do comp test kn cylinder 6 normal cylinder psi is 400-425 and if it drops to 325 bad cylinder
