Sponsored by: Real Truck
Keypad entry doesn't work
Old Jun 10, 2013 | 12:56 PM
NM3's Avatar
NM3
I have a 2004 F-250 SD Crew Cab XLT.
The keypad on the door is factory and does not have a battery and its power comes from the computer its hardwired to.
The key pad does light up when u hit it but doesn't stay on, even when your still entering numbers in.
The problem is that it doesn't unlock the truck and its only locked the truck once (by pressing 7-8 and 9-0).
I have the correct code for it, which I found printed in big numbers on the computer under the dash.
Also, I tried reprogramming the key less entry stuff and the keypad wouldn't respond.
Anyone have a problem like this? Thanks in advanced.
Old Jun 10, 2013 | 05:03 PM
greentree ford's Avatar
greentree ford
Check for loose wire inside door
Old Jun 10, 2013 | 06:32 PM
Hotpocket's Avatar
Hotpocket
these keypads are wireless like our key phobe..mine lights up and everything but it wont work either
Old Jun 10, 2013 | 09:21 PM
greentree ford
Some are hardwired some are not. If yours lights up and everything you have a programming issue
Old Jun 11, 2013 | 02:02 PM
NM3's Avatar
NM3
Yeah, the factory ones are hardwired. Then, if the dealer installed them they should be remote.
I checked all the connections in the door and to the computer. Nothing unplugged.
I took the switch apart and realized that you have to press either side of each button. Now, I can lock the car by pressing 7 & 8 but can't unlock it with the code.
If I press numbers in it for a solid 2 min the keypad light starts to flash.
I'll search for information on programming issues when I get home tonight.
Old Jun 11, 2013 | 04:43 PM
greentree ford
It starts flashing after 30 or 35(I forget which) strokes, that is to deter a thief from entering all 625 possible combination and opening your door
ken1509368
Feb 1, 2016 01:11 AM
Doug Gonzalez
Jul 3, 2013 12:34 AM
willisod
2009 - 2014 F150
Sep 24, 2010 10:42 PM
Black 5.4L
1997 - 2003 F150
Aug 24, 2005 09:46 PM
