Wood bed coating?
Old Jun 9, 2013 | 10:09 PM
nickmobile67's Avatar
nickmobile67
Wood bed coating?
I ordered new oak boards for my flareside. I still use my truck as a truck but I want it to look good. I'd like to do something nicer other than just paint them black again. Any tips on what to use on them?
Old Jun 10, 2013 | 07:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If I were you I wouldn't try to put any film forming finish on them if you still intend to use it 'as a truck'.
Polyurethane, varnish or epoxy will start to peel and get white underneath.
Rather, I would use something like Linseed oil or -if you want stain or color- use Watco oil. It comes in different shades.
Be sure to seal the end grain and all sides before you install your boards.
Try and saturate any mounting holes too.
This kind of finish is easy to maintain or repair, and since it is "in the wood" rather than on it, it will not peel.
Old Jun 10, 2013 | 10:34 AM
nickmobile67
Thanks for the tips. I was looking at the Mar-K site where the wood came from reading their wood finishing tests. I'm even thinking about painting it again since that would probably be the most durable. I do keep the truck inside for the most part, but it will probably still see some bad weather.
Old Jun 10, 2013 | 10:09 PM
pinkpantherbeekeeper's Avatar
Linseed oil or danish oil are good ideas. Might also want to try a deck stain. I used a clear deck stain on oak bed on a grain truck and it still oxidized to a white gray color. Keep in mine you probably want to reapply a coating every couple of years... just like you should on non treated deck. Worst thing that affects the boards is sunlight. Poly coating will peal like said above unless you reapply often.
Old Jun 11, 2013 | 12:24 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I've been on boats since birth, and in the building trades for 30+ years.
A working truck's bed is not some static display, like they show on the Mar-K website.
Spar varnish and UV inhibited epoxies are fine for brightwork, but still need to be maintained often.
If there is a chip, crack or flake it needs to be addressed ASAP.
Boat decks need to either be oiled or bleached and scoured often.
UV is the killer.
It breaks down the lignin in the wood and leaves the stringy cellulose fibers.
A truck bed won't see the extremes of a marine environment, but it will see a lot more abuse than bare feet and Topsiders.
Try a deck oil like Flood CWF-UV5.
Stay away from Sikkens products.
I guarantee you will need to re-apply an oil more often than annually.
Depending on the exposure, every few months... just a quick wipe and you're done.
Then again, how often would you wash & wax your truck?
Old Jun 11, 2013 | 09:34 AM
nickmobile67
I wash my truck close to weekly, wax it monthly, and it's kept inside. But again, I still use it as a truck and I probably won't be waxing the inside of the box. Do you think I'm better off just painting it?
Old Jun 11, 2013 | 11:42 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't think you have to treat the bed wood weekly or even monthly.
Depending on where you are, maybe 2-3 times a year if you oiled it.
(after the initial multiple coats)
Seems a shame to cover that beautiful grain, and painting only seals the inevitable moisture IN, fostering rot.
falconwagon62
Nov 27, 2010 01:25 PM
oldguy829
16
Sep 29, 2009 09:49 PM
51truck
25
Jan 31, 2009 04:52 PM
Mick1930
24
Nov 2, 2008 11:31 PM
red on top
Sep 17, 2007 10:00 PM
