Best easiest way to refinish bed wood
Here are the beams for my flatbed after 8 coats of varnish, I will be doing the floor of the bed the same way.
The beams and all wood under the bed should hold up a long time like this, but for the bed floor, I would still plan to re-varnish it every few years.
Ok let's back up a tad.
First of all Formbys is a furniture refinishing product that is graded for internal use....... IE no UVs or moisture - so forget it.
Second, we don't know what year truck this is or what the original bed wood boards are made of - it's important.
Third, just because the boards are gray doesn't mean they are damaged. It means the finish put on them to protect them has failed allowing them to "patina.'
If they are still solid they can be easily sanded and refinished for use.
Original Planking on Ford trucks was Hard Northern Pine from Fords own groves. It was normally painted the same color as the truck - back then, in enamel. Pine is a naturally oily wood.
If you sand it, and choose not to repaint it the color of the truck, then a few coats of thinly cut clear shellac (cut with denatured alcohol) allowed to seap in and harden (about 5 days) then about 4 coats of spar varnish (exterior), should do the planks justice!
As said there is no easy 'lasting finish' you need to put the work in for a quality and long lastin finish. If you're really not that bothered about it lasting though, and just want to tart it up maybe look at the microporous type woodstains. Sand it back and chuck a couple of coats on and it'll be good for a short while...
There's lots of threads about bed finishes.
But th ebest thing I can do is refer you to the MAR-K web site. They have a tech library where they have test results for different types of finishes and processes - it's pretty good.
Here's the link:
MAR-K Classic Truck Parts made in Oklahoma City, USA
https://www.ford-trucks.com/forums/8...od-finish.html
https://www.ford-trucks.com/forums/7...d-install.html
Here's the link:
Jonnyuma
08-31-2016 05:01 PM
Stephan
1999 to 2016 Super Duty
02-23-2012 10:43 AM
Greywolf
02-13-2010 03:08 PM
