Removing Emissions stuff /smog
Old Jun 9, 2013 | 07:18 PM
burton7.3's Avatar
burton7.3
Hey guys I have a 1995 ford 150 I want to removing all the Emissions stuff it has the tube that goes from head to head and the tubes that goes to the pump up front. what all do I have to do to take that stuff off and I'm replacing the oil pan and pan gasket should I put sealant on the corners of the gaskets? Thanks
Old Jun 9, 2013 | 08:04 PM
Encho's Avatar
Encho
The Southernmost Mod
Why do you want to remove the smog equipment, you'll have absolutely no gains from doing it performance-wise, I can tell you because I've had to remove most of mine for lack of spares in my country, my mileage actually went down about 2 MPG...
Old Jun 9, 2013 | 08:17 PM
burton7.3's Avatar
burton7.3
The tubes are rust out and it on a sand dune truck least stuff I have to worry about going bad and it make the engine bay look better
Old Jun 9, 2013 | 10:05 PM
Encho's Avatar
Encho
You just need to plug the two holes in the back... I can't remember the size of the plugs required right now, you can remove the Thermactor (smog air pump) and run a shorter belt (some engines might require a delete pulley, see that the new belt route won't cause problems). There are some issues with the EGR, I've been told you should leave it alone, take the pump and the tubes out and be done with it.
Old Jun 10, 2013 | 05:05 AM
burton7.3's Avatar
burton7.3
Ok thanks for the info
Old Jun 10, 2013 | 06:20 AM
Intimnasc's Avatar
Intimnasc
They also make a smog delet pully that makes the pump removal very clean and no belt rerouting. Whichever method works for you.
Old Jun 10, 2013 | 06:29 AM
burton7.3's Avatar
burton7.3
Yea I'm going to do some more research and see what I can fine thanks for all the info
Old Jun 10, 2013 | 10:38 AM
White Max's Avatar
White Max
Assuming we're dealing with a '95 5.0L here...
The crossover tube at the back of the heads can be removed. The holes in the back of the heads can then be plugged with a pair of 5/8-11 x 3/4" long bolts. Leave the vacuum lines that supply vacuum to the TAB and TAD solenoids, but plug the top port on each.
If your FEAD has the upper idler with the tensioner located just below the alternator, you'll need a 94" belt (940K6). The routing of the belt is as follows: from the crank pulley around the water pump pulley, to the ps pump, to the ac compressor, under the tensioner, to the alternator, then back to the crank pulley. You won't use the upper idler pulley in this configuration.
Old Jun 10, 2013 | 11:16 AM
burton7.3's Avatar
burton7.3
Sorry guys it a 95 351w
Old Jun 10, 2013 | 01:55 PM
White Max's Avatar
White Max
Then you'll need a different length belt. I don't recall the correct length off the top of my head, but it has been posted in a few threads here.
Old Jun 10, 2013 | 02:10 PM
burton7.3's Avatar
burton7.3
Ok I'll search for it thanks for all the info
sparr0
Aug 14, 2015 10:04 PM
TX92F150
17
May 10, 2012 10:23 AM
Red91XLT
1978 - 1996 Big Bronco
Oct 24, 2007 10:05 AM
postalpete
Apr 2, 2005 09:43 AM
RJCarp2
Jul 23, 2004 11:57 PM
