Does anyone have any advice on what needs to be done to remove a smog pump from an 85 f150 with a carburated 351 HO? I would like to be rid of it. I am not necessarily interested in removing other emissions stuff, just this and the myriad of hoses that go with it. I am not in an area where testing is done.
If you want a little performance increase just take the belt to the pump off, but if you want to take the pump off to clean up the engine compartment....I'm not quite sure how to do that.
If you have catalytic converters, removing the belt will cause them to overheat. I would suggest removing the cats & the smog pump & putting plugs in the smog passages in the rear of the heads. There may be more involved, but this is all I can think of right now.
no that is wrong, the air pump actually heats the catalyst up more.
i removed mine on my 300l6 when i replaced the engine...didn't make much of a difference really to me, but the engine i put in had no emissions on it so it was just waisting space so i pulled it
more then likely you WON'T be able to find a shop that will remove them for you due to the epa blah blah and some other bull. your best bet is to cut em out yourself and take it to shop to have the pipe welded up.
