Disabling smog pump
Old Jul 23, 2004 | 08:51 AM
RJCarp2's Avatar
RJCarp2
Disabling smog pump
Had this in the exhaust forum, was suggested I ask it here. Since I have no cats, the air tube for them is pretty useless. This is all that the smog pump runs, correct? If so, where is it and how do I disable it? Thanks.
Old Jul 23, 2004 | 04:08 PM
83Van's Avatar
83Van
It's as simple as removing the drive belt...that's it. I'd go ahead and unbolt the pump to save weight and get rid of the "plumbing" to clear up some of the clutter. You'll just have to block off the exhaust manifold fitting with a pipe plug.
Old Jul 23, 2004 | 08:58 PM
85e150's Avatar
85e150
Remove as advised if you don't have to pass smog each year on visual inspection. Otherwise, just pull the belt.
Old Jul 23, 2004 | 09:54 PM
Crazz's Avatar
Crazz
if its a serpatine belt, you'll have to get a smaller one, most places ask if you have a air pump/smog pump so should be easy to get another belt, was thinking about removing mine soon,
Old Jul 23, 2004 | 10:22 PM
Franken-Truck's Avatar
Franken-Truck
Why go through the trouble? It can't possibly eat that much power, or save that much weight. Personally, I would like to know what kind of PSI it puts out and if it would be suitable for on-board-air.
Old Jul 23, 2004 | 11:57 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Air Pump puts out 31 Lbs an hour. Ford # E1AE-A2A
nottelybill
Sep 9, 2016 09:01 AM
John R. Thomas
Apr 24, 2016 09:04 PM
gameover1974
Jan 6, 2016 05:27 PM
xxshine
Sep 11, 2011 07:09 AM
shammee
Modular V10 (6.8l)
May 10, 2004 08:33 PM
