Hello, I just got a 1956 F250 to work with and noticed that one of my 8 lug wheels was plenty rusty and was wondering what later model 8 lug wheel would fit my hub..It has what looks like the original 16" wheels and are tube type. I would probably be better off with a modern tubeless wheel if it is a common size. Let me hear from you folks, thanks.
well if they are 16inch rims and 8bolt im thinking they are then most any 8 bolt wheel from a ford 95 and back "should" fit i believe.
I could be wrong though.
Any 8 lug Ford style (they have a slightly larger center hole) will work, they were used up through the '90's. Your stock '56 hubcaps won't fit the later wheels though...
