Gauges Not Working
Old Jun 13, 2013 | 11:17 AM
Intimnasc's Avatar
Intimnasc
Got most of it fixed today. Apparently in the 95 some wiring in the dash has changed from 94 so I had to trace out the wires related to the diode/resister splice and but splice it into the 95 engine bay harness.
Now for the new problems. After fixing this some other things that couldn't be seen because of the blown fuse have popped up.
1) The transmission shifts between all 4 gears fine and the trailering button turns off the overdrive but the light flashes for the overdrive off. Any ideas?
2) The 95 engine bay harness came without wiring for the air bag sensors so the airbag light flashes continuous. Is there a way other than just taking the bulb out to disable this?
Old Jun 13, 2013 | 08:09 PM
Intimnasc's Avatar
Intimnasc
Well I ran a ode reader tonight and go 2 KOEO codes, 334 and 624. Starting the research tonight on what these mean and how to fix them. As soon as I know something I'll shar my finings.
Old Jun 13, 2013 | 10:09 PM
SideWinder4.9l's Avatar
SideWinder4.9l
If that's the case, then the 1995 Harness must have came from a F-250/350.
Beginning in 1994, F-150's received airbags in the steering wheels, whereas the F-250/350 trucks did not.
Old Jun 14, 2013 | 04:39 PM
Intimnasc's Avatar
Intimnasc
Yes the wiring harness, PCM, and motor came from a 95 F250.
I have solved the EGR issue though I don't understand why its this way. There apparently are 2 different pintel sensors for these trucks and when I bought my new one I bought the wrong one. There is a black one that puts out a slightly higher signal voltage and a grey one. I bought the black and needed the grey.
As far as the code 624 I am not sure what to do. I am going to take it to the dealership Onday. Them SoB's built it they can figure it out. 100 bucks an hour labor I hope it doesn't take them too long.
Old Jun 16, 2013 | 12:26 AM
Intimnasc's Avatar
Intimnasc
Well I got my problems all solved today. After having several beers yesterday and not messing with the truck any I decided to take one last look art the trranny harness before throwing money away. In the 94 harness there was an additional "hot" wire that went to the pressure control. When looking at the digram today I saw whgere the splice was made and added the wire to the harness and she wo4rks fine. What killed me the most about this was they use the same hot wire they just take it there on a different pin. It actually splices to the red wire in the same harness and is a white/red stripe wire. Anyways for all who care and tried to help thank you.
Only one code left and it will clear when I get it custom tuned. Code 173 O2 sensor reading too rich.
moneypit79
Nov 21, 2014 08:20 AM
DutchmanAZ
Aug 5, 2014 08:56 PM
njneer1
1978 - 1996 Big Bronco
Apr 10, 2011 06:51 PM
JimmyFW1
Feb 12, 2010 11:46 AM
SmokingSS
Electrical Systems/Wiring
Feb 12, 2005 12:14 AM
