74 F100 Cluster HELP ! ! !
Old Feb 6, 2010 | 06:59 PM
JimmyFW1's Avatar
JimmyFW1
My bro-in-law & I are working on a 74 F100 for an older family friend.
The ribbon wire on the back of the current cluster is SHOT. I found one with the configuration in FL & had it shipped here to SC.
But the dash is still not working. We've checked all the fuses. But are starting to chase the wiring. What kind of a nightmare are we into?
Any suggestions??
Old Feb 6, 2010 | 09:06 PM
78fordboy2010's Avatar
78fordboy2010
Im not sure exactly, but I am having the same issue with my 78. I replaced the ribbon plate on the back of the cluster as well to no eval. I am chasing the wires tomorrow and will let you know what I come up against.
Old Feb 7, 2010 | 01:47 AM
grandmas77f150's Avatar
grandmas77f150
Did you check the current in the wires going to the cluster?
Old Feb 8, 2010 | 09:25 AM
JimmyFW1's Avatar
JimmyFW1
We've checked & tested every wire in the cluster harness. We traced them w/ the help of the schematic in a Haynes Manual (not the most helpful book for this truck, BTW). Tested all resistance ranges, ground points, and sending units. The individual gauges test fine, but the D@MNED ribbon on the back seems to be the problem. I have ordered 3 different clusters from 3 different salvage yards & they have all been worn out. I understand that this is a 36 year old part, but does SOMEONE make a replacement ribbon for this application??
If it were up to us, we'd bypass the factory gauges, as others have done here, and replace them w/ more reliable up-to-date equipment. but the truck owner wants it looking as original as possible.
Another option we are considering is bypassing the harness & cluster (except for the lighting) and straight wiring each gauge. Has anyone else on here done that?? They appear to just be simple 2 contact gauges w/ a common ground resistance wire.
THANKS IN ADVANCE FOR YOUR HELP...
Old Feb 8, 2010 | 10:05 AM
kadrocker's Avatar
kadrocker
1967-79 Full Size Truck/bronco - Dash Parts - Instrument Clusters & Covers
new circuit ribbons. pricey, but new.
Old Feb 8, 2010 | 02:22 PM
JimmyFW1's Avatar
JimmyFW1
Thumbs up
Originally Posted by kadrocker
I would buy one of those in a quick minute, if they fit a 74 configuration...
But THANKS. That was a awesome find...
Old Feb 8, 2010 | 03:09 PM
kadrocker's Avatar
kadrocker
Ohh man. I'm sorry dude! I thought all 73 to 79 were wired the same way.
Can anyone confirm if they'll work or not for his 74?
Old Feb 8, 2010 | 03:47 PM
JimmyFW1's Avatar
JimmyFW1
Lightbulb
Ain't no big thing. I appreciate the help...
I can confirm. The pin configuration for the harness is different on the 74's. they have a 13 pin configuration; 8 on the top, 5 on the bottom. I called Bronco Graveyard to see if they had anything not listed on the site that would be compatible, and they just don't carry it. Said these are actually printed overseas & they'd been waiting years for them to come out...
Old Feb 12, 2010 | 11:46 AM
JimmyFW1's Avatar
JimmyFW1
Lightbulb
OK, I found this one on Blue Oval Truck Parts. It's 114.95. The ones on Bronco Boneyard are around 60-70. Anyone know of any other options? I'm desperate, but I don't know if I'm $115 desperate yet...
Bert65
Feb 28, 2017 01:16 PM
Tiggie
Dec 22, 2016 11:50 AM
SemperFi_YEMX
Aug 24, 2016 07:48 PM
f100today
Jul 19, 2016 09:29 AM
dowurk74
18
May 12, 2011 12:19 AM
