wiring....
Old Jun 6, 2013 | 12:36 PM
highoctane74's Avatar
highoctane74
wiring....
All of a sudden my truck will no longer turn off with the key, I had to pull off the coil wire. Any ideas?
Also there is a larger gauge Black/yellow wire that I found cut inside the firewall harness. If I am not mistaken those wires are used to feed power to most accessories? The other 2 identical to it are hooked to my underhood fuse panel, should that one be also?
1979 F-250 supercab
Old Jun 6, 2013 | 01:04 PM
highoctane74
Well I figured out the Black/yellow. It was power for the heater motor. Still can't figure out ignition problem.
Old Jun 6, 2013 | 04:42 PM
fmc400's Avatar
fmc400
MSEE
Sounds like a bad ignition switch, or hacked up wiring. Since you've already found cut wires behind the dash, I suspect the latter.
ford_fan_59
Mar 6, 2023 06:29 PM
68f10059
Sep 19, 2013 07:01 PM
rwjr
1978 - 1996 Big Bronco
Feb 21, 2007 05:03 AM
dorkpunch
Jun 9, 2005 11:53 AM
robz5.0
Feb 24, 2004 09:25 AM
