Sponsored by: Auxito
99 f150 theft light
Old Jun 4, 2013 | 09:52 PM
copenhagen110's Avatar
copenhagen110
99 f150 theft light
i have a 99 f150 with a 4.6 that will not start. it has sat for a while now. when i go to turn the key to turn it on it cranks and cranks and cranks but wont start. the theft light blinks like crazy and the odometer reads dashes. there is also a relay which i do believe is the pcm relay that clicks like crazy. when the relay clicks and the key is first turned to the on position the fuel pump will turn on and off as the relay clicks. we tried putting a scan tool to it to try to pull a code and the scan tool wont connect. i do believe its the pats system kicking, but i also think its related to this relay clicking like a mother, maybe a bad connection in the junction or something. but im not really sure how to try to start and find the problem. i have also tried replacing the relay that clicks and the new relay does the same thing. any help on this would be greatly appreciated.
Old Jun 5, 2013 | 12:05 AM
Bluegrass 7's Avatar
Bluegrass 7
Turn the key to run, do not crank and let set a few minutes to see if the Theft light flashes a code.
If yes post it.
Good luck.
Old Jun 5, 2013 | 12:08 AM
ford2go's Avatar
ford2go
welcome to FTE
I DON'T really know much about your truck, but there's a post just a few down that's very similar ( truck won't start acts like no fuel...)
His problem was the receiver for the chip in the key. Others have apparently had issues with the key and have had it reprogrammed.
Check out the thread and maybe search on 'PATS' or 'key programming' -- stuff like that.
Good Luck,
hj
Old Jun 5, 2013 | 12:42 AM
blueeyedfordguy's Avatar
blueeyedfordguy
X2 ford2go!!!! The theft light is flashing because the truck is not reading the chip in the key to allow power to pump fuel. Had a f150 of this gen. At work And we would mix the keys now and then and crank it and wonder why it wouldnt start! Haha. Well if you have a spare jump to that key. But I'm 99% sure your key is not disabling the theft system. I have a 97. No chip. Wonder when they started to chip the keys?
Old Jun 5, 2013 | 07:35 AM
projectSHO89's Avatar
projectSHO89
Nope, he does NOT have a PATS problem. He has a PCM relay power problem that needs to be fixed before anything else.
If the PCM doesn't get power to properly boot up FIRST, nothing else will work and you'll waste time chasing PATS or fuel delivery system phantoms.
Old Jun 5, 2013 | 12:26 PM
copenhagen110
how would i go about diagnosing the pcm problem?
Old Jun 5, 2013 | 03:01 PM
projectSHO89
If the PCM Power Relay is clicking/chattering like you said, then either it's bad, or it has a bad power of ground connection. Might be a corroded socket, a corroded ground, a corroded fuse socket, a bad ignition switch or a few other things.
Old Jun 5, 2013 | 09:44 PM
copenhagen110
i looked on alldata today at school and its actually the fuel pump relay. but looking at the wiring diagram the fuel pump relay im pretty sure runs into a lot of things that control the pcm. since i couldn't get the code reader to work again today im going to go with your theory that the computer doesnt have enough time to boot up. i tried to program a clicker for the locks and the truck wouldnt go into programming mode. so tomorrow im going to try to take about the junction box and start from there.
Old Jun 7, 2013 | 11:56 AM
Sideonx3's Avatar
Sideonx3
Smile Er.... have you tried...
I was running into that issue today, changed 30 amp fuse in position 30
and the problem stopped
(bear in mind that im repairing a 2001 xltso the fuse position may be different)
Cheers
sideonx3
Stroker 6.0 fan
22
Oct 10, 2021 09:02 AM
Icefan71
1997 - 2003 F150
Jun 5, 2021 02:50 PM
GonzoCSU
Jun 16, 2017 10:25 AM
jhuggs82
Sep 10, 2015 10:15 AM
muscletruck
2004 - 2008 F150
21
Feb 17, 2013 10:42 AM
