rail mount fuel pump
Old Jun 9, 2003 | 09:14 AM
lw2muddy's Avatar
lw2muddy
Sometime back I found a wire hanging under the left rail and found it was from the 2nd fuel pump. Since the tank pump stopped again and it would not start I made a temp connection to the coach interior light relay in the engine compt. I can't find where it was originally connected.
Would it have been to the fuse block under the left dash?
Eventually your advise will cure all my problems.
Old Jun 9, 2003 | 11:55 AM
broncobasher's Avatar
broncobasher
I have no idea about the wire, but if it would run without the high pressure pump (the one on the frame rail), it sounds like someone replaced the intank low press pump with a high pump and disconnected the high pump on the rail. I have heard of some people replacing the high pump with a upgraded one and disconnecting the in tank pump but never the other way around. Newer fords come with just one in tank high pump w/o the frame rail pump. That may be what yours was replaced with.
Just guessing.
BroncoBasher
Rhino99
Modular V10 (6.8l)
Feb 21, 2016 06:11 PM
pgguru
Apr 10, 2015 12:40 PM
gman97005
Jan 25, 2015 06:53 PM
insatiate76
Jul 29, 2013 10:09 AM
DNJSDAD
Modular V8 (4.6L, 5.4L)
Feb 17, 2009 07:28 PM
