No start what the....
Old Jun 3, 2013 | 08:34 AM
strokin83's Avatar
strokin83
Well she finally decided to give me some greif. I was working out here on a site north of OKC and the truck has been running great all day. I shut it off to do the job and 20 mins later it will not start. I pulled the codes P2291 low ICP. One thing I noticed is that I cant hear the lift pump running when I turn the key on. I even drained the bowl on it and still can't hear anything. So I'm thinking bad lift pump or something. Does anyone else have a similar circumstance? I'm looking for any input I can get. I'm stuck here in a hotel until they get it running. Thanks
Old Jun 3, 2013 | 12:39 PM
Shake-N-Bake's Avatar
Shake-N-Bake
In case it hadn't already crossed your mind....
Have you checked the fuses? I am not too familiar with the newer trucks but the 7.3 models have a quirky issue where a fuel bowl heater can short out and blow a fuse. Problem is the PCM is also powered by the same circuit. No PCM...no start.
Old Jun 3, 2013 | 02:00 PM
darren32's Avatar
darren32
P2291 - Injector Control Pressure Too Low - Engine Cranking
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Description: </TD><TD style="BORDER-LEFT: medium none" vAlign=top colSpan=4 align=left>The powertrain control module (PCM) monitors the fuel rail pressure (FRP) during the engine cranking. If the FRP does not increase to the calibrated threshold while the engine is cranked this DTC is set. </TD></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Possible Causes: </TD><TD style="BORDER-LEFT: medium none" vAlign=top colSpan=4 align=left>
  • FRP sensor or circuitry
  • Fuel pump control - low pressure pump
  • Fuel pump control - high pressure fuel injection pump
  • Fuel volume control valve or circuitry
  • Fuel pressure control valve or circuitry
  • Poor fuel quality
</TD></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Diagnostic Aids: </TD><TD style="BORDER-LEFT: medium none" vAlign=top colSpan=4 align=left>The FRP sensor, fuel pressure control valve and fuel volume control valve values can be monitored by accessing the FRP_A PID, the F_PCV and the F_VCV PID. </TD></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Application </TD><TD style="BORDER-LEFT: medium none" vAlign=top align=left></TD><TD vAlign=top align=middle>Key On Engine Off </TD><TD vAlign=top align=middle>Key On Engine Running </TD><TD vAlign=top align=middle>Continuous Memory </TD></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>All </TD><TD style="BORDER-LEFT: medium none" vAlign=top align=left></TD><TD vAlign=top colSpan=3 align=middle>GO to Pinpoint Test M . </TD></TR></TBODY></TABLE>
Old Jun 3, 2013 | 02:05 PM
Shake-N-Bake
Good point. That code obviously means the PCM is awake....
Is P2291 the code that comes up when the HPFP tanks?
Old Jun 3, 2013 | 02:08 PM
darren32's Avatar
darren32
Here is pinpoint test M, let us know how it goes
Old Jun 3, 2013 | 02:12 PM
darren32's Avatar
darren32
Hopefully it's just the sensor or the low pressure pump
Old Jun 3, 2013 | 07:03 PM
strokin83's Avatar
strokin83
Yea I'm hoping it's not a high pressure pump and complete fuel system problem. The lady service writer called me back earlier and was not helpful. She said the tech said it was a fuel pressure problem and wanted to do more testing tomorrow. I'm hoping and praying it's something easy and covered. I can't really afford $12,000 out of pocket right now or the down time that goes with it. Trying to stay positive. Thanks for all the info guys.
Old Jun 3, 2013 | 07:11 PM
Shake-N-Bake
Yes, either of those would be more agreeable. If the sensor was found to be out of range during the comprehensive component monitor test, would the PCM not ignore that value and insert a value from a general look up table? That is how the HEUI systems work.....maybe the newer systems are controlled differently.
Positive thoughts heading your way. Hoping for something simple and you have your truck back soon.
Old Jun 4, 2013 | 10:59 AM
tolliewolly's Avatar
tolliewolly
good luck with it and keep us posted.
Old Jun 4, 2013 | 02:36 PM
strokin83's Avatar
strokin83
The service writer called me earlier and said it was the lift pump. Im keeping my fingers crossed. They should have it done today so back to OKC I go in my rental Dodge Charger. I'll post later with the final result.
Old Jun 4, 2013 | 03:17 PM
tolliewolly
great news! Hope it all turns out good. Thanks for the report.
Old Jun 4, 2013 | 08:12 PM
strokin83's Avatar
strokin83
Heard again from the dealership. It runs! I'll be picking her up tomorrow it was all covered as well. I was kind of curious if it would be since I have 39,000 on her. I didn't buy the extended bumper to bumper but I'm glad it was. Thanks again for everyone's input.
Old Jun 4, 2013 | 09:01 PM
Shake-N-Bake
Awesome. The power of wishful thinking!
Old Jun 4, 2013 | 09:18 PM
FishOnOne's Avatar
FishOnOne
Zack,
Thanks for the report...
Old Jun 4, 2013 | 10:33 PM
darren32's Avatar
darren32
Good to hear
pocketmaster
1997 - 2003 F150
21
May 10, 2022 04:25 PM
ka2rkv
6.7L Power Stroke Diesel
Sep 27, 2017 08:52 AM
Domino2205
Feb 22, 2012 10:30 PM
Shooter141IFE
6.4L Power Stroke Diesel
Jun 22, 2010 05:23 PM
Wizzerd
1997 - 2003 F150
Jan 19, 2010 11:41 PM
