Sponsored by: Real Truck
Rear end vent
Old Jun 2, 2013 | 08:52 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Rear end vent
This is something to check, I found the vent line pinched closed on my 2000 F350 when I was trying to find out why it was leaking. When I was under my 2013 installing the hitch I checked it and found the same problem. The clip doesn't pinch it closed right away but it will happen if you don't move the clip.
Denny
Old Jun 3, 2013 | 02:48 AM
ATP Pilot's Avatar
ATP Pilot
thanks! I'll have to check and move the clip too.
Old Jun 3, 2013 | 05:07 AM
senix's Avatar
senix
Great tip. Guess I will have to check mine.
Old Jun 3, 2013 | 07:07 AM
jdadamsjr's Avatar
jdadamsjr
just to clarify - ASSume the second pic is the way it should be ?
and for us old, slow folks that don't like to crawl around looking
is that outside the drivers side frame rail near the rear tire or ???
Thanks in advance !
Old Jun 3, 2013 | 07:13 AM
redford's Avatar
redford
FTE Leadership Emeritus
Denny, go drive in some mud or something. The bottom of that truck is way too clean.
Old Jun 3, 2013 | 02:04 PM
rvpuller's Avatar
rvpuller
Thanks in advance !
Yes the second pic is the way it should be, it's on the left hand side (drivers side) and it goes up to the top of the frame just behind the axle.
Denny
Old Jun 3, 2013 | 04:47 PM
King-bRanch's Avatar
King-bRanch
Good Tip....Rep's given
Many people NEVER think to check that Vent Tube, i actually disconnect & blow air through it whenever iam under there & think about it.
Thats how my dad blew the wheel seal's out on his truck a few years ago, had mudd caked around the tip of the tube. Could not blow through it....
Old Jun 3, 2013 | 04:51 PM
rvpuller's Avatar
rvpuller
It got to the point that every time I pulled my trailer I would push grease out the pinion seal that's when I started looking for a blocked vent.
Denny
Old Jun 3, 2013 | 06:53 PM
ATP Pilot's Avatar
ATP Pilot
Just went slide my Fat butt under the truck and no way was my clip pinching the line, I could easy slide the clip up the line to the fitting. But I moved it anyway.
5starCabF-3
May 3, 2019 10:12 AM
daVincidoc
Jan 3, 2017 01:32 PM
49'er
Aug 8, 2012 09:35 AM
Cooter55
19
Dec 9, 2010 06:58 AM
