Transmission Question
Old Jun 2, 2013 | 11:56 AM
old blue beast's Avatar
old blue beast
Ive got a 77' F-350 and was wondering what kind of trans i got. I thought because it was a 1-ton, it would be a C6. I checked the door code and refrenced it to what my shop manual says, and apparently i have a C4. Does this make sense? i mean, isnt the C4 a light duty trans?
Old Jun 2, 2013 | 12:01 PM
fmc400's Avatar
fmc400
MSEE
That's a pretty vague question given the fact that you've provided almost no information on your truck, such as the engine. You also didn't specify if you have a manual transmission or an automatic; based on your post I assume you meant to say it's an automatic.
I don't know what your truck has, and neither does anyone else on the internet. Crawl underneath your truck and look. If the corner of the pan is notched and there are 17 bolts, it's a C6. If the pan is almost a square and there are 11 bolts, it's a C4.
Old Jun 2, 2013 | 12:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, if the F350 has an I6 it could be an FMX. That one will have a cast iron case.
The FMX was only factory installed on F350's with the 300 6 cylinder.
Old Jun 2, 2013 | 12:11 PM
JWC 3's Avatar
JWC 3
FMX =14 pan bolt . C4 =11 pan bolt . C6 =17 pan bolt
Old Jun 2, 2013 | 12:25 PM
old blue beast
oh, sorry. Its got a 460 BBF, automatic, Camper Special, Supercab. And thank you for the help guys, ill check the pan bolts
Old Jun 2, 2013 | 02:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
With a 460 it'll be a C6. Ford never put a C4 behind a big block.
BigJon626
Jun 6, 2013 09:22 AM
cr500monster
May 4, 2013 03:16 PM
daddy172005
Jun 27, 2009 09:25 PM
racinherby
Apr 28, 2004 05:04 PM
brokebronco
Nov 29, 2002 06:53 AM
