Major problems, tons of codes!
Old Jun 1, 2013 | 03:42 PM
och's Avatar
och
I think my 2005 E350 with 129k miles is on its last leg.
These are the codes i pulled
C1145 Right Front Sensor Input Circuit Fault
P0404 EGR Performance
P0672 Cylinder 2 Glow Plug Circuit
P0678 Cylinder 8 Glow Plug Circuit
P0700 Transmission Control System Fault
P1335 EGR Position Sensor Minimum Stop Performance
P0757 Shift Solenoid B Stuck On
P2701 Transmission Friction Element B Apply Time Range/Performance
Old Jun 1, 2013 | 03:46 PM
parkland's Avatar
parkland
I can't be of much help, but don't get too scared; sounds like you might need a few glow plugs, EGR valve / cooler, maybe a shift solenoid?
Old Jun 2, 2013 | 12:33 AM
BLADE35's Avatar
BLADE35
Looks like a Few problems
A Speed sensor might be throwing trans Off
Do you have a Tunner?/
Done a Trans fluid flush at any time??
Try to clean egr valve
Old Jun 2, 2013 | 01:24 AM
Fulthrotl's Avatar
Fulthrotl
you've got stuff all over the map. this is a shot in the
dark, but it's a cheap shot:
check to make sure you have good voltage to the main fuse
block, and PCM power. i had a +12VDC main battery cable
loose on a binding post, and every time i hit a bump,
i'd throw different codes.... weird stuff, all over the map.
tightened up the bolt, and everything was wonderful.
Old Jun 2, 2013 | 03:30 AM
Yahiko's Avatar
Yahiko
I agree bad voltage can do all sorts of strange things.
I would also check the ground points and the cables to start with.
The glow plug can be an easy one. Pull the plugs out of the controller
not the plugs then selves and look and see if it's gotten wet or has dirty
contacts. Clean with some contact cleaner and apply some dielectric grease
and see if that clears it up. The GPM (Glow Plug Module) is on the passenger
side front edge of the valve cover. Aluminum fined with 2 plugs one green
one black. It's easy to remove and inspect.
Your truck is no where near being dead. You need to do some live data
reporting so we can give you a hand. Do you have access to something
like a Scanguage II or the AE with the Ford bundle?
Right front wheel speed sensor for ABS and the sensor can be replaced if needed.
This one is the ABS sensor and in the past and yes I had the problem
the plug got wet and it was acting up. I got the same error. Find the cable
on the back side of the wheel well and you will see the plug. Clean it and
put it back together with some dielectric grease and see if that problem
goes away. Also after doing the repairs make sure to clear the codes
after you write them down.
Let us know and good luck
Sean
Old Jun 2, 2013 | 08:50 AM
barkwill's Avatar
barkwill
unplug the cooling fan and rescan it. take the valve out and replace it cause its sticking. dont forget to scrape out the carbon completely when youre there or it will haunt you and for the trans codes, the fan sometimes interferes with transmission reference voltage and makes it do wierd things.
Old Jun 8, 2013 | 07:50 PM
och's Avatar
och
I fixed everything besides transmission codes. Can anyone help with those?
Old Jun 8, 2013 | 08:21 PM
BLADE35's Avatar
BLADE35
Have you checked the wires to the Trans?? with DVM???
You may need a New Trans silinoid
Check the Wires from the PCM/TCM to Silinoid
Old Jun 8, 2013 | 09:16 PM
mustang_309's Avatar
mustang_309
Well how did you fix it?
Old Jun 9, 2013 | 01:49 PM
och's Avatar
och
This one was easy to fix, replaced the ABS sensor and the problem is gone.
This one was fixed by cleaning EGR valve - my mechanic said he pulled tons of gunk out of there and the intake.
Fixed by replacing glow plug control module
Took the truck to the transmission shop, and the guy said he cannot find anything wrong mechanically with the transmission, but he said solenoid B isn't getting power. He said he believes the other code can be fixed if P0757 is fixed. He suggested I replace transmission harness. I replaced both lower and upper transmission harness, but the problem persists. Don't know what else to do.
Flyview
Oct 25, 2017 12:37 PM
norman2012
Sep 14, 2017 04:18 PM
Jaime74656
Aug 20, 2013 05:00 AM
Budlight592
May 15, 2009 05:49 PM
