Sponsored by: Real Truck
4x4 low not working
Old May 30, 2013 | 09:05 PM
rhamm150's Avatar
rhamm150
4x4 low not working
what are some simple checks, my 4x4 low range doesnt engage, just stays in 4 hi. 2003 f350 screw v10. thanks
Old May 30, 2013 | 09:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
Do you have a manual shift 4 wheel drive system, or do you have the little **** on the dash that you twist? When you do try to shift to 4L, what procedure are you following? Are you stopped? Is the transmission in N or P?
Old May 30, 2013 | 09:38 PM
Ford_F350_SD's Avatar
Ford_F350_SD
You have to be in neutral to engage 4x4 low.
Old May 31, 2013 | 06:56 PM
rhamm150's Avatar
rhamm150
its electric and have trans in neutral, have tryed with all 4 wheels off the ground also, it does nothing doesnt even sound like the motor on t case is working but goes in and out of 4 high just fine, could the dash switch be bad, cant be a complex system by the looks of it just a switch and electric motor, thanks for the help
Old May 31, 2013 | 07:56 PM
DaveCinIN's Avatar
DaveCinIN
Could be a relay under the hood by the fuse box. Also your foot needs to be on the brake peddle for it to shift.
Old Jun 11, 2013 | 07:07 PM
rhamm150's Avatar
rhamm150
found problem i believe, found 2 wires pulled out of connector on dash switch, works fine now, thanks for help. sorry didnt reply sooner been workin 16 hour days.
Slapshottr
Dec 21, 2016 05:52 AM
shn_lck
Dec 10, 2012 01:45 PM
E-Dragon
Nov 26, 2009 11:46 PM
richep
1983 - 2012 Ranger & B-Series
Nov 10, 2004 04:50 PM
Pete Johnson
19
Oct 16, 2004 11:29 AM
