I may be be asking this in the wrong section, so forgive me if I am. I am curious to know why I have locking hubs on my 4x4 f250 since I believe it is shift on the fly. I was cleaning my rims today and noticed they are in the "locked" position. Should they be in the locked position or the "auto" position?
It is a 2009 f250 4x4 that is new to me and I just want to make sure its in the correct position. Any help would be greatly appreciated.
Thanks
They should be left in Auto, which allows them to free-wheel when not engaged. If you have them "locked" then you are turning your front differential and driveshaft, creating unnecessary wear and fuel consumption. Auto lock will engage your front hubs whenever engaged. The "lock" feature on your hubs is a mechanical back up if the vacuum autolock isn't working...... I think ;-)
Thank you so much. I'm keeping my fingers crossed that my gas mileage will improve a little now.
The shift on the fly feature requires one full rotation of the front wheels before 4x4 is fully engaged. So if you get buried before using the electric switch in the cab, time to get dirty and manually lock them.
Thank you for the information. I recently purchased this truck (about a week ago) and was cleaning it today when I noticed the hubs were in the locked position. Apparently, it has been that way since I bought it. I'm really hoping that my gas mileage will improve? Do any of you guys think it hurt anything to drive it with the hubs in the locked position?
Thanks again for all the info. This forum is a lifesaver for me.
No won't hurt the truck, but if you kept them in locked it would cause premature wear. Actually you should try to lock them in every month for 20 miles or so to keep all the internal part of the front diff and the u joints completely lubricated.
my question, why was both hubs locked in the first place. i would be willing to be the vacuum part of the auto locking hubs has and issue and rather than fixing the problem they just locked the hubs so the 4 wheel drive would work. you may want to test to see if the auto lock works for future reference. congrats on he good lookin truck
Thanks Joe, the truck was a certified pre-owned and I did get a complete print out of the trucks maintenance/previous work history. However, you bring up a good point. I'm not familiar with 4 wheel drive since this is my first one. I can try and put it into 4 wheel drive and see if there are any issues. Other than going out and climbing a hill, (at the risk of sounding very stupid) how will I know if auto lock is working or not?
Thanks again.
Dave
Put the hubs in auto, turn the dash switch to 4x4. Drive ahead a few feet. Turn the wheel to full lock. If everything engaged, the truck will hop around a bit if your on solid ground. Then you know everything is working. To try 4low, stop, put truck in neutral, push the brake and switch to 4low. Should go in.
Yes, I did that and it did "hop around". It felt more like I ran over something and it was stuck under my tires. Very strange. I didn't put it in 4low though. I assumed that if 4high worked, I didn't really need to try 4low. I guess I can give 4low a try tomorrow, but it seems like everything is working fine. I really appreciate all the advise everyone is giving though. So thankful I found this forum.
Thank you everyone.
