Sponsored by: Kumho
bleeding the power steering pump
Old May 29, 2005 | 11:19 PM
70T351W's Avatar
70T351W
I just replaced the power steering pump on my 70 f100 and was wondering how to bleed the air out. I was also told to use power steering fluid instead of atf. so what kind of fluid do I use.
Old May 29, 2005 | 11:50 PM
ford390gashog's Avatar
ford390gashog
use transmission fluid and there should not be a need or a way to bleed a power steering pump
Old May 30, 2005 | 12:50 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
If it's a fresh system I prefer NEO power steering fluid used in race cars, has anti-foam, wear and varnish additives. It has higher lubrication properties than ATF. If ATF were a lubericant the clutches in an auto trans would slip. Also add a large cooler not Ford's little joke of a loop.
.....=o&o>.....
Old May 30, 2005 | 08:13 AM
70T351W's Avatar
70T351W
Good info guys thanx but this power steering pump is making a growling noise and it has fluid that is why I thought it needed the air bled out of it.
Old May 30, 2005 | 09:12 AM
plugugly's Avatar
plugugly
I did a swap to a saginaw and filled mine new pump, started the truck, and had a little graoning, and was hard to steer. I drove around teh neighborhood and checked the fluid level every so often. I all quit after about fifteen minutes or so. If it does not go away make sure your lines are right and not clogged.
Old May 30, 2005 | 11:09 AM
"Beemer Nut"
Air in the pump will make noise that will go away, a scored pump will growl or whine as it's destroyed.
.....=o&o>.....
Old May 30, 2005 | 11:27 AM
hatemakings/n's Avatar
hatemakings/n
I may be wrong but I think my manual said to leave the dipstick out and turn full lock to lock as needed to bleed it. My book went missing though.
Old May 30, 2005 | 12:48 PM
rebocardo's Avatar
rebocardo
To bleed just about any power steering system, raise the front wheels on jackstands (remember you are turning the wheels - so place properly), take the ps. cap off, start engine, turn slowly left to right, right to left, without hitting the steering stops.
Old May 30, 2005 | 09:17 PM
70T351W's Avatar
70T351W
Thanx, works great now guys.
ErrorS
Oct 20, 2022 02:54 PM
93truck
15
Sep 5, 2013 07:37 PM
titanminator
Mar 30, 2012 10:24 AM
93XLT150
Feb 15, 2011 06:44 PM
gingerbreadmaniac
May 11, 2004 08:58 PM
