Replace Egr cooler only?
Old Jun 1, 2013 | 11:32 PM
  #46
BLADE35's Avatar
BLADE35
Sometimes you just got to Dive In
And the Tunner came out the closet or Did I miss that LOL
Now Lets Hope they Don't Find a Bad Head At 1K Apeice
You Should STRONGLY CONSIDER Doing a COOLANT Flush BEFORE It Goes In
Stuff a Hose In IT!! Open the Drains and let it RIP FULL ON
since you cant run it Much With Blown EGR Cooler
Just Tell them you want to drain cooling system Water ASAP Block Drains and ALL When you get there It will rust Fast So Just get water Out
Your Main Goal is to end up with a Spotless cooling system
Lots of ShOPS tell you how well they will Flush and all they Get is a Spill-N-Fill
The Best thing here is to end Up with ELC
ELC=Extended Life Coolant
Oh Ya Tell them you still WANT The EGR VALVE INSTALLED and Plugged IN!!
Old Jun 2, 2013 | 11:37 AM
  #47
emmagator's Avatar
emmagator
What is the purpose of keeping the valve plugged in?
Old Jun 2, 2013 | 11:44 AM
  #48
jswartz84's Avatar
jswartz84
For proper cooling fan operation
Old Jun 2, 2013 | 12:01 PM
  #49
emmagator's Avatar
emmagator
Ok thanks, i remember reading something about that. Ill read up on it and make sure they leave it in.
Old Jun 2, 2013 | 03:11 PM
  #50
BLADE35's Avatar
BLADE35
Add $400.00 More for a Tuner to shut your CEL Off with the EGR Deleate
You could wait till your Done and see what Happens but 06 usualy triggers a CEL
Old Jun 2, 2013 | 03:15 PM
  #51
emmagator's Avatar
emmagator
Yea i have an sct, and im pretty sure most of the tunes i run disable the egr. Thanks
Old Jun 2, 2013 | 11:26 PM
  #52
BLADE35's Avatar
BLADE35
So Great Better Take the Wife out to Dinner your 400 ahead
Mine always says you spend more on that truck then Me When I Bought the EGR Deleate was straw that Broke the Camels Back LOL
Old Jun 2, 2013 | 11:30 PM
  #53
BLADE35's Avatar
BLADE35
He has to Pull the Injectors out or should
But may leave in to save Him a Penny IDK
But Now would be a Great Time to Clean Injector Spool Valves up
Stiction Fix
Must read, Instruction and Video
Also be a Great Time to change Top Injector Oring to the HPO Rail when you have the injector out
Old Jun 2, 2013 | 11:33 PM
  #54
BLADE35's Avatar
BLADE35
How Many Miles you Have??
Old Jun 3, 2013 | 08:00 AM
  #55
emmagator's Avatar
emmagator
53k, Im gonna have them dissemble turbo clean etc. Injector test and new o-rings. Basically the quote they gave my included a 6.0 solution kit. Has a bunch of o-rings and gaskets in it. Not sure if all of it is necessary though.
Also ford has an updated turbo drain tube and feed tube, are these things i should consider?
robert421960
Dec 11, 2012 08:44 AM
Hurricane67
Oct 4, 2011 08:30 PM
88stang1
Sep 16, 2010 04:16 PM
paulkcbulm
May 14, 2010 11:43 PM
gb'sfx4
Jan 27, 2010 06:44 PM
