Replace Egr cooler only?
Old Jun 1, 2013 | 07:24 AM
  #31
Rusty Axlerod's Avatar
Rusty Axlerod
Here is a thread with a video cheezit posted a while back. It shows how a bad EGR cooler could be diagnosed as a bad headgasket. Pressure rises and falls quickly with rpm and is very high. The point being many Techs would have said the gaskets were bad when in fact it was the EGR cooler on this truck.
https://www.ford-trucks.com/forums/1...9-08-03-a.html (be sure to read the whole thing)
Also, while I agree with Benny that the pressure check is the proper way to diagnose- a failing cylinder would point you in the right direction- but cranking with the starter doesn't make the temps and pressure the gasket must seal against when the engine is running. Some have had gaskets leak when towing and in high boost situations and not leak when driving easy in town.
I'm beginning to think the only way to diag a leaking headgasket -for sure- is with the gasket in your hand.
Old Jun 1, 2013 | 10:06 AM
  #32
emmagator's Avatar
emmagator
I have a question, and please to dont this the wrong way. Im not trying to argue with anyone.
If a compression test will tell you definitively whether your headgaskets are bad, then why isnt that the standard test? Not one of the dozen shops i called suggested a compression test. Ive viewed several diagnostic tutorial videos, read several dozens threads similiar to mine, without the mention of a compression test to diagnose bad headgasket. There are thousands of threads similiar to mine, where guys are in my exact predicament, trying determine their problem. Why arent they all just running a compression test and be done with it?
Old Jun 1, 2013 | 11:48 AM
  #33
BLADE35's Avatar
BLADE35
Cost
Because the Glow Plug Harness can get Broke since you must Remove Glow Plugs to get the tester in there
Takes Time
They Can do the cooling pressure test Faster then getting 1 GP Out Or be Hooked up ready to Go Super Fast
There Bank Account is Low
Old Jun 1, 2013 | 12:10 PM
  #34
raptor131's Avatar
raptor131
here is a simple test you could try, remember they also sell this device, but this is a reputable company that i trust, it may not be definitive , but is good info either way, simple to preform.
Check out this video on YouTube:
Old Jun 1, 2013 | 12:18 PM
  #35
BLADE35's Avatar
BLADE35
That's the Video I Ment
THANKS RAPTOR!! reps sent
Old Jun 1, 2013 | 12:20 PM
  #36
BLADE35's Avatar
BLADE35
Originally Posted by Yahiko
To do the compression test you need a tester + this
adaptor to reach into the glow plug hole
Amazon.com: OTC 6660 Compression Tester Adapter: Automotive
The price on Amazon was better than Ebay
The tool you want is an OTC tool part number OTC 6660.
Sean
Thanks sean I reped Ya
In Fact I reped EVERYONE
Except Scott I was in Rep Time Out sorrey Man Catch Ya Later
Old Jun 1, 2013 | 01:17 PM
  #37
emmagator's Avatar
emmagator
Yea, im in the process of getting some rubber to run that test. Thanks for the video.
Old Jun 1, 2013 | 01:56 PM
  #38
Yahiko's Avatar
Yahiko
Me too : You must spread some Reputation around before giving it to BLADE35 again.
Thanks Benny
Sean
Old Jun 1, 2013 | 06:58 PM
  #39
emmagator's Avatar
emmagator
Ok, first and foremost i would like to acknowledge all of those who have followed and posted helpful info on this thread. I performed the bubbles in the jar test like that in the video and it leads me to believe i have a bad headgasket. I know many will think i havent done enough to confirm that i have a bad headgasket, but i have decided to do the full deal and be done with it.
The shop im considering quoted my $4025 for, sinister full egr delete with uppipe, oem headgasket w/arp studs, ford updated oil cooler, dissemble turbo and cleaning, injector test, and sinister coolant filter. I figure since i run a tuner, tow heavy, and run it hard with an 8" lift, this would be the best decision for the present and the future of my truck. Thanks again.
Old Jun 1, 2013 | 07:22 PM
  #40
jswartz84's Avatar
jswartz84
Who is going to do the work for you, if you don't mind me asking?
Old Jun 1, 2013 | 09:02 PM
  #41
emmagator's Avatar
emmagator
RPM diesel in Grants Pass
Old Jun 1, 2013 | 10:06 PM
  #42
Ryanr's Avatar
Ryanr
Thanks for the reply on the compression tester.
Old Jun 1, 2013 | 10:15 PM
  #43
diesel_dan's Avatar
diesel_dan
I think you had a whole bunch of Very smart folks on the 6.0 weigh in on your concerns about spending money where you maybe shouldn't. It's a great place here, isn't it? We all wanted it to be less, but in the end, you will trust the truck after you're done with this....
Happy trails...
Old Jun 1, 2013 | 10:44 PM
  #44
jswartz84's Avatar
jswartz84
I've heard good things about RMP so good luck and keep us posted.
Old Jun 1, 2013 | 10:49 PM
  #45
emmagator's Avatar
emmagator
I will, thanks
