Sponsored by: Real Truck
Transfer Case Shifter
Old Sep 17, 2006 | 07:00 PM
Lefty980's Avatar
Lefty980
Just bought a 1996 F250 and when I checked the 4wheel drive it was stuck, I hit it with WD 40 and was able to move it better but not all the way. My last attempt I broke the shifter and now am in a jam. Does anyone know where I can get a new shifter and how difficult is this to do on my own. Thanks
Old Sep 17, 2006 | 07:07 PM
powrstrkn''s Avatar
powrstrkn'
Geeeez
Most of the time if you can't shift the transfer case putting the truck in neutral or park helps and will get it in
You can get the shifter at the dealer or a parts jobber of your choice, or a salvags yard if money is tight and used parts don't bather you.
The R&R of the shifter shouldn't be too bad if you have hand tools and some mechanical know how
Welcome to FTE
Old Jul 2, 2013 | 11:53 AM
TBraley's Avatar
TBraley
I have just purchased a 93 4x4 and with the shifter in Neutral the **** says you pull back to 4L and you push forward back into neutral, that works. Now it says to push down and forward for 4h and 2h, NO WAY it wouldn't move. So, I got under the truck with it in neutral and the 4wheel shifter in neutral. After looking at the bracket with the notches there is no possible way to push the stick forward at all. All of the notches from neutral show you have to pull the lever toward the seat but its still not possible because you still have to push it down and it wont budge. Any suggestions would be great. Thanks.
Old Aug 19, 2013 | 05:51 AM
harrisonpromo39's Avatar
harrisonpromo39
I bought a 2000 Ford F150 4x4 . When i try to move the shifter it does not move forward and backwards at all. It does go left . But does not move up or down at all. Can anyone help?
carlislefordf250
Mar 13, 2015 05:57 PM
gt40racing
32
May 29, 2012 07:45 PM
jhjandal
Aerostar
Jun 20, 2005 09:58 PM
