Sponsored by: Auxito
2003 f150 fx4
Old May 28, 2013 | 02:07 AM
NickGf150's Avatar
NickGf150
Cool 2003 f150 fx4
So, I've got an '03 F150 FX4 model, 4x4, 5.4 liter engine, and about 140,000 miles on it. Lately, I noticed a slowly growing (in volume) sound coming from under the hood. I have been told it might be an exhaust leak, however; I am not so sure. Anyway, this sound has become higher pitched, and is continuing the make the noise at higher speeds, as it used to stop around 40 mph. The sound is a high pitched whining type of sound, maybe a little 'winding', too. As I accelerate, the sound follows, becoming louder and higher pitched. If anyone has had this problem, or knows what it might be, I would greatly appreciate the feedback.
Thanks,
Nick
Old May 28, 2013 | 04:00 PM
Georgeandkira's Avatar
Georgeandkira
feedback
Hello, "...it used to stop at 40 mph..." makes me think it's a bearing which has lost its last bit of lube. Slacken or remove the accessory belt and start the engine briefly and see if the noise goes away. An idler bearing will feel rough. You might be able to get the noise to change pitch by hitting the brights and power window switches at the same time-that would point to an alternator bearing. Try turning the steering wheel when it's making the noise. It could be the power steering pump. Kira
stemo76
6.7L Power Stroke Diesel
May 18, 2023 03:08 PM
jayman2
24
Mar 17, 2012 07:00 PM
joeyd71
Mar 24, 2011 08:57 PM
Olddog66
Aug 17, 2009 08:10 PM
1BadKingRanch
1997 - 2003 F150
Feb 19, 2006 10:25 AM
