Another delay-wiper question.
Old May 26, 2013 | 11:39 AM
6t6merc's Avatar
6t6merc
I'm adding the variable-speed wiper switch and module to my '66 with one-speed wipers. It doesn't look like the plug-and-play installation that some have described. It isn't clear which wire should go where. The parts have these wires:
Single speed motor: Orange/black, black, green.
(New)two-speed motor: red, white, black, blue.
Module plug: white/purple, dk blue/orange, blk/grn, red, blk/red, white, blk/white. The variable switch includes a washer switch so I guess a couple wires aren't needed.
Can anyone tell me how to hook this up?
TIA, Eric
Old May 26, 2013 | 04:53 PM
Customcab's Avatar
Customcab
Replace your one speed motor with the two speed; but you will have to use the short connecting arm from your one speed and bolt/ clip (can't remember if mine was secured with a nut or clip) it on to your two speed motor; then attach the isolating arm to the short arm. You will have to run a ground wire from the motor to any place you can screw it to cause a ground. Then use the newer wiper switch and plug the pig tails into your harness. The newer switch will be about a 1/4 " long ; you can cut the tip off and reattach the ****.
Hope I didn't confuse you. There's been a thread or so on this upgrade.
Old May 26, 2013 | 05:11 PM
Mattrod68's Avatar
Mattrod68
so let me get this straight, if i already have the 2 speed wiper than it is plug and play with the exception of a ground wire and the **** shortening?
thanks in advance
matt
Old May 26, 2013 | 05:18 PM
jowilker's Avatar
jowilker
Not to argue, I swapped in a 76 motor with arm exchange mentioned on my 66, used delay switch and modual. I am lazy and have yet to shorten the stem for the control button.
It really is a piece o cake.
John
Old May 26, 2013 | 07:00 PM
1972RedNeck's Avatar
1972RedNeck
I haven't shortened the rod either. Just take a pair of nippers to the ground wire.
Old May 26, 2013 | 09:21 PM
6t6merc's Avatar
6t6merc
I'm ok with the mechanical issues John and Mitch, the problem I have is that the new 2-speed motor has four wires, the module has seven, and the colours don't match. Any ideas?
Eric
Old May 27, 2013 | 05:11 AM
jowilker's Avatar
jowilker
Eric, It's been a while, but I believe the hot and ground wire connect to the motor. The regular 2spd switch wire goes to the front of the dash. The delay is plugged into the switch connection with an additional ground from the module. Like I say it has been more than 10 years so I could have missed something.
John
jim6346
19
Jan 27, 2024 01:40 PM
66 F-100
Dec 12, 2008 08:37 PM
red brewer
Nov 21, 2004 08:17 PM
RANGERGUY1980
Electrical Systems/Wiring
May 30, 2004 08:41 PM
